[Qgis-user] distance between rectangle polygon in Qgis
Nicolas Cadieux njacadieux.gitlab at gmail.com
Mon Feb 15 12:45:08 PST 2021
I think you will need to delete duplicate nodes, then export the polygon nodes (vertices) to a new point layer.  Then, I would apply a distance matrix. Write back if you want more details.  This is for the distances between the nodes within a polygon right?
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 15 févr. 2021 à 12:35, Marin Mirosevic <marin.mirosevic at bouvet.no> a écrit :
> Hello,
> Is there a way to calculate distance between points of the polygon ?
> I tried to find in “filed calculator “ under geometry but I found just $perimeter and that is whole bounding line of the polygon.
> With regards/ Vennlig hilsen
> Marin Mirosevic
> Consultant
> Mobil +47 909 67 511
> Bouvet Norge AS
> bouvet.no
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210215/b50aa18d/attachment.html>
