[Qgis-user] distance between rectangle polygon in Qgis
Marin Mirosevic
marin.mirosevic at bouvet.no
Mon Feb 15 14:41:14 PST 2021
Hi Nicolas
Yes that is what i mean
Dohvati Outlook za iOS<https://aka.ms/o0ukef>
Šalje: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Poslano: Monday, February 15, 2021 9:45:08 PM
Prima: Marin Mirosevic <marin.mirosevic at bouvet.no>
Kopija: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Predmet: Re: [Qgis-user] distance between rectangle polygon in Qgis
I think you will need to delete duplicate nodes, then export the polygon nodes (vertices) to a new point layer. Then, I would apply a distance matrix. Write back if you want more details. This is for the distances between the nodes within a polygon right?
Nicolas Cadieux
https://gitlab.com/njacadieux<https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgitlab.com%2Fnjacadieux&data=04%7C01%7Cmarin.mirosevic%40bouvet.no%7Cdfbdbd2dfbe8417cc23908d8d1f29711%7Cc317fa72b39344eaa87cea272e8d963d%7C1%7C0%7C637490187268925839%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=YjBanhsLCeLKrRJGDzWqtiJXXYt5%2FKCGYT3sDg%2FqG9w%3D&reserved=0>
Le 15 févr. 2021 à 12:35, Marin Mirosevic <marin.mirosevic at bouvet.no> a écrit :
Hello,
Is there a way to calculate distance between points of the polygon ?
I tried to find in “filed calculator “ under geometry but I found just $perimeter and that is whole bounding line of the polygon.
With regards/ Vennlig hilsen
Marin Mirosevic
Consultant
Mobil +47 909 67 511
marin.mirosevic at bouvet.no<mailto:marin.mirosevic at bouvet.no>
Bouvet Norge AS
bouvet.no<https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.bouvet.no%2F&data=04%7C01%7Cmarin.mirosevic%40bouvet.no%7Cdfbdbd2dfbe8417cc23908d8d1f29711%7Cc317fa72b39344eaa87cea272e8d963d%7C1%7C0%7C637490187268925839%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&sdata=vmJchi0MS%2F1gFzrNxjx6reYtByhVuttrYx%2B02xPNIug%3D&reserved=0>
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210215/ae5b686e/attachment.html>
