[Qgis-user] distance between rectangle polygon in Qgis
kirk
kirk at nortekresources.com
Mon Feb 15 14:44:17 PST 2021
Another option is to convert the polygons to lines and the calculate the length if each line in the attribute table.Sent from my Galaxy
-------- Original message --------From: Marin Mirosevic <marin.mirosevic at bouvet.no> Date: 2021-02-15 6:41 p.m. (GMT-04:00) To: Nicolas Cadieux <njacadieux.gitlab at gmail.com> Cc: qgis-user at lists.osgeo.org Subject: Re: [Qgis-user] distance between rectangle polygon in Qgis
Hi Nicolas
Yes that is what i mean
Dohvati Outlook za iOS
Šalje: Nicolas Cadieux <njacadieux.gitlab at gmail.com>
Poslano: Monday, February 15, 2021 9:45:08 PM
Prima: Marin Mirosevic <marin.mirosevic at bouvet.no>
Kopija: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Predmet: Re: [Qgis-user] distance between rectangle polygon in Qgis
I think you will need to delete duplicate nodes, then export the polygon nodes (vertices) to a new point layer. Then, I would apply a distance matrix. Write back if you want more details. This is for the distances between the nodes within a polygon right?
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 15 févr. 2021 à 12:35, Marin Mirosevic <marin.mirosevic at bouvet.no> a écrit :
@font-face
{font-family:"Cambria Math"}
@font-face
{font-family:Calibri}
p.x_MsoNormal, li.x_MsoNormal, div.x_MsoNormal
{margin:0in;
font-size:11.0pt;
font-family:"Calibri",sans-serif}
span.x_EpostStil17
{font-family:"Calibri",sans-serif;
color:windowtext}
.x_MsoChpDefault
{font-family:"Calibri",sans-serif}
@page WordSection1
{margin:70.85pt 70.85pt 70.85pt 70.85pt}
div.x_WordSection1
Hello,
Is there a way to calculate distance between points of the polygon ?
I tried to find in “filed calculator “ under geometry but I found just
$perimeter
and that is whole bounding line of the polygon.
With regards/ Vennlig hilsen
Marin Mirosevic
Consultant
Mobil +47 909 67 511
Bouvet Norge AS
bouvet.no
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210215/3a3cd3d1/attachment.html>
