[Qgis-user] distance between rectangle polygon in Qgis
    C Hamilton
    adenaculture at gmail.com
    Mon Feb 15 17:19:22 PST 2021
There is a nifty function provided by the "Shape Tools" plugin called
"Geodesic measurement layer". It will create a new layer of your polygon
layer and measure each segment between nodes in the polygon or measure the
total circumference of the polygon. You can select which you want. You can
choose what measurement unit you want to use (miles, kilometer, meters,
etc) and it records everything in the attribute layer and even styles the
new layer so that it shows all the measurements in the QGIS display. The
function also works on a line layer. It makes it very easy to instantly see
distances with lines or polygons.
https://plugins.qgis.org/plugins/shapetools/
Calvin
On Mon, Feb 15, 2021 at 12:35 PM Marin Mirosevic <marin.mirosevic at bouvet.no>
wrote:
> Hello,
> Is there a way to calculate distance between points of the polygon ?
> I tried to find in “filed calculator “ under geometry but I found just *$perimeter
> *and that is whole bounding line of the polygon.
> With regards/ Vennlig hilsen
> *Marin Mirosevic*
> *Consultant *Mobil +47 909 67 511
> *marin.mirosevic at bouvet.no <marin.mirosevic at bouvet.no>*
> *Bouvet Norge AS*
> *bouvet.no* <http://www.bouvet.no/>
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210215/ecdd0d72/attachment-0001.html>
