[Qgis-user] Does "Organize columns" work for anybody? (QGIS 3.16)
Alexandre Neto senhor.neto at gmail.com
Tue Feb 16 18:59:33 PST 2021
Hi Jeff,
If the profile worked, that means something in your current default profile
is causing that.
Normally, the culprit is a third-party plugin, but you excluded that
already. So it must be something else. It would be interesting to compare
both profile folders trying to find what may be causing the problem.
Anyway, when you have several profiles, the last profile to be closed, will
be the one chosen the next time you open QGIS. If that doesn't work, you
can manually determine which profile should be used by editing the
profiles.ini fil inside the profiles folder:
C:\Users\<your_username>\AppData\Roaming\QGIS\QGIS3\profiles\profiles.ini
The easier way to access this file, is to go to Settings > Users Profiles >
Open current profile folder... and then move one folder down.
To remove a profile, you can simply delete the profile folder. If
no profile folder is found, QGIS will recreate a new Default one.
Best regards,
Alexandre Neto
QGIS User Support
www.cooperative.net
On Wed, Feb 17, 2021 at 2:42 AM Jeff Sonnentag <jsonnentag at llenviroinc.com>
wrote:
> Interesting.  So a new profile fixed it so Organize Columns works, but
> what is stored in the profile other than the plugins that are set to
> install?  (I noticed the ones installed before aren’t in the new profile.)
> So I unchecked the plugins in the original “default” profile and that
> didn’t fix the “Organize Columns” crashing.  And the new profile has the
> Recent Projects variable set to 1 just like the default profile was.
> The new profile is working now, but is there a way to just reset the
> default profile?
> Looking at the arrangement of things (profiles in subdirectories) is it
> possible to create a new profile and then copy that into the “default”
> profile subdirectory?  Would that be the recommended way of resetting the
> default profile?
> *From:* Alexandre Neto <senhor.neto at gmail.com>
> *Sent:* Tuesday, February 16, 2021 5:24 PM
> *To:* Jeff Sonnentag <jsonnentag at llenviroinc.com>
> *Cc:* qgis-user <qgis-user at lists.osgeo.org>
> *Subject:* Re: [Qgis-user] Does "Organize columns" work for anybody?
> (QGIS 3.16)
> Hi,
> It's working here on QGIS 3.16.3 (Ubuntu 18.04 and Windows 10).
> Can you try creating a new profile (settings > user profiles > new
> profile) and try again?
> If not, can you share a sample of your data.
> Alexandre Neto
> QGIS User support
> www.cooperative.net
> On Wed, Feb 17, 2021 at 12:18 AM Jeff Sonnentag <
> jsonnentag at llenviroinc.com> wrote:
> So the next problem leading to immediate crash/lockup comes when I try to
> manage multiple columns (I want to hide a bunch of them and right-clicking
> and choosing Hide Column for each one takes forever).
> Does it actually work in QGIS 3.16.3 for anybody?
> When the icon for “Organize columns” (pencil in front of a table) is
> clicked (doesn’t matter what shapefile) QGIS stops working and must be shut
> down with the Windows 10 Task Manager.
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/attribute_table.html#hiding-and-organizing-columns-and-enabling-actions
> This list of known bugs in the change log mentions that it doesn’t work if
> the table is empty, but the table is NOT empty and it still doesn’t work.
> https://qgis.org/en/site/forusers/visualchangelog316/index.html
> Organize columns not working if the table is empty
> #38653 <https://github.com/qgis/QGIS/issues/38653>
> Upstream (Qt)
> So is it just me or everybody?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210217/59805670/attachment-0001.html>
