[Qgis-user] Symbol lines every km, moving when changing scale or moving map
    Prud'homme Jérémie
    p.jeremie at gmail.com
    Fri Feb 19 02:05:12 PST 2021
Tested too fast :(
Behavior is ok when zooming in, but still problems when zooming out
(whereas the entire feature is visible !).
See here : https://www.zupimages.net/viewer.php?id=21/07/ehlo.gif
Circles should follow the strokes generated with the tool "Points along
geometry".
Jérémie.
Le ven. 19 févr. 2021 à 10:03, Prud'homme Jérémie <p.jeremie at gmail.com> a
écrit :
> Hi,
> Thank you very much Nyall, this one was pretty well hidden.
> With clipping unchecked, behavior is as expected for my use case.
> Jérémie.
> Le jeu. 18 févr. 2021 à 23:29, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
>> On Wed, 13 Jan 2021 at 06:33, Prud'homme Jérémie <p.jeremie at gmail.com>
>> wrote:
>> > Hi,
>> > I'm using QGIS 3.10.
>> > I tried to use only symbology to display a stroke every km along a road.
>> > The project CRS is 2154 (Lambert 93).
>> > When adding a ""symbol line" with an interval of 1000 map units (meter
>> for 2154) – or 1000 meters at scale, same result – I achieve to display
>> symbols every km.
>> > Problem is when I move the map or change scale, the symbols do not
>> always stay in place. They are sometimes misplaced.
>> > I've been told that problem can be that the first node of the line is
>> not always the reference to calculate the intervals.
>> From the bottom of the symbol widget, click the "Advanced" button and
>> uncheck "Clip features to canvas extent".
>> Nyall
>> > You can find a GIF here that displays my problem :
>> https://zupimages.net/viewer.php?id=21/02/nvr2.gif
>> > Circles are symbols via Symbology.
>> > Strokes are symbos on points generated vith the tool "Points along
>> geometry".
>> > You can see that circles are not always at the same place as the
>> strokes.
>> > Is it a "normal" behavior ?
>> > Anyway as a user I would expect that symbols are always generated at
>> the same place from the starting node.
>> > Thanks for your enlightments on this.
>> > Jérémie.
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210219/13ade348/attachment.html>
