[Qgis-user] Symbol lines every km, moving when changing scale or moving map
    Andreas Neumann
    a.neumann at carto.net
    Fri Feb 19 02:12:30 PST 2021
Hi Jérémie,
Do you have geometry simplification turned off? See "Settings" -->
"Options" --> "Rendering" --> "Enable feature simplification ..."
Make sure this is deactivated (I think it is enabled by default).
Greetings,
Andreas
On 2021-02-19 11:05, Prud'homme Jérémie wrote:
> Tested too fast :(
> Behavior is ok when zooming in, but still problems when zooming out
> (whereas the entire feature is visible !).
> See here : https://www.zupimages.net/viewer.php?id=21/07/ehlo.gif
> Circles should follow the strokes generated with the tool "Points along
> geometry".
> Jérémie.
> Le ven. 19 févr. 2021 à 10:03, Prud'homme Jérémie <p.jeremie at gmail.com>
> a écrit :
> Hi,
> Thank you very much Nyall, this one was pretty well hidden.
> With clipping unchecked, behavior is as expected for my use case.
> Jérémie.
> Le jeu. 18 févr. 2021 à 23:29, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit : On Wed, 13 Jan 2021 at 06:33, Prud'homme Jérémie
> <p.jeremie at gmail.com> wrote:
>> Hi,
>> I'm using QGIS 3.10.
>> I tried to use only symbology to display a stroke every km along a
>> road.
>> The project CRS is 2154 (Lambert 93).
>> When adding a ""symbol line" with an interval of 1000 map units (meter
>> for 2154) - or 1000 meters at scale, same result - I achieve to
>> display symbols every km.
>> Problem is when I move the map or change scale, the symbols do not
>> always stay in place. They are sometimes misplaced.
>> I've been told that problem can be that the first node of the line is
>> not always the reference to calculate the intervals.
> From the bottom of the symbol widget, click the "Advanced" button and
> uncheck "Clip features to canvas extent".
> Nyall
>> You can find a GIF here that displays my problem :
>> https://zupimages.net/viewer.php?id=21/02/nvr2.gif
>> Circles are symbols via Symbology.
>> Strokes are symbos on points generated vith the tool "Points along
>> geometry".
>> You can see that circles are not always at the same place as the
>> strokes.
>> Is it a "normal" behavior ?
>> Anyway as a user I would expect that symbols are always generated at
>> the same place from the starting node.
>> Thanks for your enlightments on this.
>> Jérémie.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210219/b3530c29/attachment.html>
