[Qgis-user] Symbol lines every km, moving when changing scale or moving map
    Prud'homme Jérémie
    p.jeremie at gmail.com
    Fri Feb 19 04:40:35 PST 2021
I had simplification turned on, indeed...
I deactivated it :
- in the Options as you mention, so that it is deactivated for newly added
layers
- in my layer options (Rendering properties)
And it is ok now.
It makes sense that if the line is simplified the distance vary !
Thanks Andreas.
Jérémie.
Le ven. 19 févr. 2021 à 11:12, Andreas Neumann <a.neumann at carto.net> a
écrit :
> Hi Jérémie,
> Do you have geometry simplification turned off? See "Settings" -->
> "Options" --> "Rendering" --> "Enable feature simplification ..."
> Make sure this is deactivated (I think it is enabled by default).
> Greetings,
> Andreas
> On 2021-02-19 11:05, Prud'homme Jérémie wrote:
> Tested too fast :(
> Behavior is ok when zooming in, but still problems when zooming out
> (whereas the entire feature is visible !).
> See here : https://www.zupimages.net/viewer.php?id=21/07/ehlo.gif
> Circles should follow the strokes generated with the tool "Points along
> geometry".
> Jérémie.
> Le ven. 19 févr. 2021 à 10:03, Prud'homme Jérémie <p.jeremie at gmail.com> a
> écrit :
> Hi,
> Thank you very much Nyall, this one was pretty well hidden.
> With clipping unchecked, behavior is as expected for my use case.
> Jérémie.
> Le jeu. 18 févr. 2021 à 23:29, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
> On Wed, 13 Jan 2021 at 06:33, Prud'homme Jérémie <p.jeremie at gmail.com>
> wrote:
> > Hi,
> > I'm using QGIS 3.10.
> > I tried to use only symbology to display a stroke every km along a road.
> > The project CRS is 2154 (Lambert 93).
> > When adding a ""symbol line" with an interval of 1000 map units (meter
> for 2154) – or 1000 meters at scale, same result – I achieve to display
> symbols every km.
> > Problem is when I move the map or change scale, the symbols do not
> always stay in place. They are sometimes misplaced.
> > I've been told that problem can be that the first node of the line is
> not always the reference to calculate the intervals.
> From the bottom of the symbol widget, click the "Advanced" button and
> uncheck "Clip features to canvas extent".
> Nyall
> > You can find a GIF here that displays my problem :
> https://zupimages.net/viewer.php?id=21/02/nvr2.gif
> > Circles are symbols via Symbology.
> > Strokes are symbos on points generated vith the tool "Points along
> geometry".
> > You can see that circles are not always at the same place as the strokes.
> > Is it a "normal" behavior ?
> > Anyway as a user I would expect that symbols are always generated at the
> same place from the starting node.
> > Thanks for your enlightments on this.
> > Jérémie.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210219/bde45b5f/attachment-0001.html>
