[Qgis-user] Help for QGIS installation /Aide pour installer QGIS
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Tue Feb 23 07:22:45 PST 2021
2.4 and 3.x can live together on the same machine in Windows. Is it the same in Linux? Probably... I figure you can install 3.10 without removing anything. Can a true Linux fan confirm?
As for the Linux installation, I followed the instructions here on a Ubuntu machine and it worked well.
https://www.qgis.org/fr/site/forusers/alldownloads.html
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 23 févr. 2021 à 05:31, SENFAUTE Gloria <gloria.senfaute at edf.fr> a écrit :
> Dear all,
> In case, you can write in French!
> I need a strong help for updating or installing last version of QGIS.
> Working in linus (Debian GNU/Linux 9 (stretch) 64 bits).
> In my computer I have a version of QGIS (2.4 ESSEN).
> In few days I will have my first training with QGIS and I must to install: QGIS 3.10.14 LTR.
> I would like to know what is the better way:
> 1)To update of QGIS 2.4 to 3.10.14 LTR, How to do it ?
> 2) To remove QGIS 2.4 and then re-install following the steps of QGIS site for linus ?
> I am so afraid of this last solution: if I remove and I cannot install the new QGIS.
> I administrator of my computer but I have also many proxis installed by my company, so I didn’t try, I am waiting for advises.
> Thank you very much !
> Gloria
> Gloria SENFAUTE
> Ingénieur Chercheur, PhD
> Expert Aléa Sismique
> Département Electrotechnique et Mécanique des Structures - ERMES
> Groupe Séisme et Impacts, EDF Lab Paris-Saclay
> 7 Boulevard Gaspard Monge
> 91120 Palaiseau
> Tél. : 33 1 78193433
> Un geste simple pour l'environnement, n'imprimez ce message que si vous en avez l'utilité.
> Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
> Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
> ____________________________________________________
> This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
> If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
> E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210223/dab2c227/attachment.html>
