[Qgis-user] Help for QGIS installation /Aide pour installer QGIS
Richard Duivenvoorde
rdmailings at duif.net
Tue Feb 23 08:40:27 PST 2021
Hi Gloria,
Not sure if you can pull up to 3.10 on Debian Stretch/9 (which is rather old....).
If I look here:
https://qgis.org/debian/dists/stretch/main/binary-amd64/Packages
it looks like that if you try to install QGIS in the normal/distro way, you will end up with QGIS 3.4 (I think, anybody can confirm ...)
Isn't it possible to upgrade your machine to Debian 10/Buster?
Then you can upgrade to 3.12 (which is 3.10 plus a little extra ;-) ) if you use the "Démarrage rapide"
https://www.qgis.org/fr/site/forusers/alldownloads.html#quickstart
Or even 3.14, 3.16 (tell your educator there is a newer LTR ;-) ) or higher?
If all fails, you could try to install a flatpak (but not sure about that either for Debian 9):
https://www.qgis.org/fr/site/forusers/alldownloads.html#flatpak
And if even that fails... and you have some experience with compiling yourself, you could compile from source...
But: Stretch is rather old, if you ask me: upgrade to Buster/10 first
Good Luck & regards,
On 2/23/21 11:23 AM, SENFAUTE Gloria wrote:
> Dear all,
> In case, you can write in French!
> I need a strong help for updating or installing last version of QGIS.
> Working in linus (Debian GNU/Linux 9 (stretch) 64 bits).
> In my computer I have a version of QGIS (2.4 ESSEN).
> In few days I will have my first training with QGIS and I must to install: QGIS 3.10.14 LTR.
> I would like to know what is the better way:
> 1)To update of QGIS 2.4 to 3.10.14 LTR, *How to do it* ?
> 2) To remove QGIS 2.4 and then re-install following the steps of QGIS site for linus ?
> I am so afraid of this last solution: if I remove and I cannot install the new QGIS.
> I administrator of my computer but I have also many proxis installed by my company, so I didn’t try, I am waiting for advises.
> Thank you very much !
> Gloria
> *Gloria SENFAUTE*
> *Ingénieur Chercheur, PhD*
> Expert Aléa Sismique
> Département Electrotechnique et Mécanique des Structures - ERMES
> Groupe Séisme et Impacts, EDF Lab Paris-Saclay
> 7 Boulevard Gaspard Monge
> 91120 Palaiseau
> *gloria.senfaute at edf.fr*
> Tél. : 33 1 78193433
> Un geste simple pour l'environnement, n'imprimez ce message que si vous en avez l'utilité.
> Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
> Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
> ____________________________________________________
> This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
> If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
> E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
> Qgis-user mailing list
