[Qgis-user] QGIS 3.18/3.16.4 LTR
Martin Bittens
martin.bittens at gmx.de
Thu Feb 25 03:32:39 PST 2021
Hello QGIS users,
I just read the messages about the latest release of the QGIS 3.18.0
and QGIS 3.16.4 (LTR) packages and must admit that now I am a bit
confused. A couple of days ago I already made an update of my existing
QGIS installation (3.10 and 3.14) using the network installer
osgeo4w-setup-x86_64.exe which I downloaded from the QGIS homepage. As
usual I selected 'Advanced Installation', the update run without any
problems, and at the end I got the updated QGIS versions 3.18.0 and
3.16.4. But now I read this (e.g.):
Long story short: you cannot upgrade from old installs and have to remove and
reinstall or use a separate directory. As the new OSGeo4W only supports 64bit
the default root directory was changed to C:\OSGeo4W, which might help with
that if you were on 64bit earlier.
Also note that it now only has one version of Python - namely 3.9, which
doesn't support Windows 7 anymore. Other updates include Qt 5.15, GDAL 3.2,
PROJ 7.2 and SAGA 7.8.
What does it mean,
- you cannot upgrade from old installs (I did it with success as far I
could see. My QGIS-projects set-up with older QGIS versions are running
obviously without any problems.
- it now only has one version of Python - namely 3.9 (I checked my QGIS
installation, there is no Python 3.9).
- Other updates include ... SAGA 7.8 (in the package list I could only
see SAGA 2.3.2 LTR and SAGA 2.1.2.)
It would be great if somebody can explain what these messages like
mentioned above are about.
Thank you very much.
Martin
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
