[Qgis-user] QGIS 3.18/3.16.4 LTR
    Jürgen E. Fischer
    jef at norbit.de
    Thu Feb 25 04:08:02 PST 2021
Hi Martin,
On Thu, 25. Feb 2021 at 08:32:39 -0300, Martin Bittens wrote:
> I just read the messages about  the latest release of the QGIS 3.18.0
> and QGIS 3.16.4 (LTR) packages and must admit that now I am a bit
> confused. A couple of days ago I already made an update of my existing
> QGIS installation (3.10 and 3.14) using the  network installer
> osgeo4w-setup-x86_64.exe which I downloaded from the QGIS homepage. As
> usual I selected 'Advanced Installation', the update run without any
> problems, and at the end I got the updated QGIS versions 3.18.0 and
> 3.16.4. But now I read this (e.g.):
Read the two paragraph in front of that: "the new packages are still in a
separate repository for testing" and "You can install them using the osgeo4w
installer on http://download.osgeo.org/osgeo4w/testing/osgeo4w-setup.exe".
As you neither did use the testing installer nor the repo, the rest doesn't
apply to you.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210225/de7a6734/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210225/de7a6734/attachment.ksh>
