[Qgis-user] Raster values in vector attributes - multipart geometries
Nicolas Cadieux njacadieux.gitlab at gmail.com
Thu Feb 25 11:37:10 PST 2021
Multi-part geometries can complicate things.  The best way is to use
Vector/Geometry tools/Multipart to Single part. You can also try the
zonal statistics module found in the processing toolbox.
Nicolas
On 2021-02-25 8:43 a.m., Giacomo Uguccioni wrote:
> A warm greeting to all,
> I ask you for help.
> I have to fill a column of a shapefile (which I believe is a
> multi-part geometry but I have to verify) with the Z (elevation)
> information.
> I would like to ask for the elevation from an online DEM resource,
> relying on the coordinates of the feature, but for now I am happy to
> be able to query a dem that I load in the same qgis project.
> The raster_value function does not work with multi-part geometries (it
> returns NULL), while the sampling raster values algorithms create a
> new layer, fact that must not happen for other reasons related to the
> sharing format of the qgis project.
> Can you give me some suggestions or some solutions? thank you so much
> *Giacomo Uguccioni*
> *Geospatial Data Acquisition & Processing*
> +39 3920431219
> Le informazioni contenute nella presente comunicazione sono riservate
> esclusivamente ai destinatari indicati in epigrafe. La diffusione del
> documento trasmesso da parte di qualsiasi soggetto diverso dal
> mittente e dal destinatario è proibita, sia ai sensi dell’art. 616
> c.p., sia ai sensi del D.Lgs. n. 196/2003 e regolamento UE n.
> 2016/679. Se avete ricevuto questo messaggio per errore, vi preghiamo
> di distruggerlo e di darcene immediata comunicazione anche inviando un
> messaggio di ritorno all’indirizzoe-mail del mittente.
> Qgis-user mailing list
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210225/78f4cace/attachment-0001.html>
