[Qgis-user] raster with distance values from a point
Kirk Schmidt kirk at nortekresources.com
Fri Feb 26 06:21:13 PST 2021
Hi Nicholas:
If you activate the various providers under the Processing toolbox
options, you can have direct access to the various algorithms I
mentioned.  I often generate a quick general model, export as a python
script and then refine the script as required.
I am running 3.16.2-Hannover.
Kirk
On 2/25/2021 9:26 PM, Nicolas Cadieux wrote:
> Interesting Kirk,
> The QGIS vector to raster conversion is not available in the graphical
> modeler or do you have another reason behind your solution? I don’t
> use much the graphical modeler so I appreciate your incite.
> Cheers!
> Nicolas Cadieux
> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>> Le 25 févr. 2021 à 15:44, Kirk Schmidt <kirk at nortekresources.com> a
>> écrit :
>> To add to Nicolas" comment:
>> 1) Create your point layer from a csv (easting, northing id) as a minimum
>> 2) If you want to stay with process modeler, use the SAGA>Raster
>> creation tools> Rasterize Algorithm to convert the point layer to
>> your required resolution and size
>> 3) Use the  GDAL>Raster Analysis>Proximity or SAGA>Raster tools>
>> Proximity Raster  to create your output.
>> Kirk Schmidt
>> On 2/25/2021 4:24 PM, Nicolas Cadieux wrote:
>>> Hi,
>>> You can cut down you use of several plugins by doing the following,
>>> 1) Create a vector point file with a single point having the
>>> numerical field containing the value 1. This file could be a csv
>>> containing WKT.
>>> 2) Use the vector to raster conversion.  (This will take your vector
>>> point file, an create a raster of x,y dimensions.  You point will
>>> become 1 and all other values will be 0.
>>> 3) Use the Proximity raster distance gdal function.
>>> This requires no plugins so it should be easy to create a graphical
>>> modeler.  My favorite way would be to go to strait Python and to
>>> call the gdal proximity function from my Python script.  If you had
>>> hundred or thousands of these to do, I could develop a Python script
>>> that could automate the entire thing.   Contact me if you have
>>> questions.
>>> Nicolas Cadieux
>>> On 2021-02-25 12:58 p.m., Fabio Falchi wrote:
>>>> Dear all,
>>>> not having received any answer, I repeat the request.
>>>> I need to speed up the process of obtaining rasters with distances
>>>> from a single point (or a single lat-lon coordinate) in it.
>>>> Manually I use this procedure:
>>>> With a georeferenced raster in a UTM projection I use raster
>>>> calculator to obtain a raster with all pixels set to zero. Then,
>>>> with Serval plug-in, I manually set to 1 the value of the pixel in
>>>> the wanted position (either by using a satellite overlay or by
>>>> using a point vector layer with the appropriate coordinates). Then
>>>> I use the proximity function under Raster>Analisys menu.
>>>> I want to make this via the Graphical Modeler, in order to be able
>>>> to make the process fast and skip the manual introduction with
>>>> Serval plug-in. At the very least, I need a mode to put the value 1
>>>> in the pixel of the selected null raster in the position givel by
>>>> lat-lon coordinates.
>>>> Thank you!
>>>> Best,
>>>> Fabio Falchi
>>>> /USC - Universidade de Santiago de Compostela/
>>>> /ISTIL - Light Pollution Science and Technology Institute/
>>>> Il sabato 20 febbraio 2021, 18:04:14 CET, Fabio Falchi
>>>> <fabio_falchi at yahoo.it> ha scritto:
>>>> Dear all,
>>>> from a single point in it. Manually I use this procedure:
>>>> Thank you!
>>>> Best,
>>>> Fabio Falchi
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Nicolas Cadieux
>> Kirk Schmidt, MScF, BScF, RPF
>> General Manager
>> Nortek Resource Solutions Inc.
>> RR # 1
>> Thorburn, NS
>> B0K 1W0
>> Tel (902) 922.3607
>> Email:kirk at nortekresources.com
>> Web:www.nortekresources.com
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
General Manager
RR # 1
Thorburn, NS
B0K 1W0
Tel (902) 922.3607
Email: kirk at nortekresources.com
Web: www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210226/8ec5f4c5/attachment-0001.html>
