[Qgis-user] Qgis-user Digest, Vol 180, Issue 52
Rodrigo Oliveira rodrigooliveira at sapo.pt
Sun Feb 21 11:30:08 PST 2021
EXMO. (A) SR.(A)
aceito
COM OS MELHORES CUMPRIMENTOS
RODRIGO OLIVEIRA
----- Mensagem de qgis-user-request at lists.osgeo.org ---------
  Data: Sat, 20 Feb 2021 12:00:02 -0800
  De: qgis-user-request at lists.osgeo.org
  Assunto: Qgis-user Digest, Vol 180, Issue 52
  Para: qgis-user at lists.osgeo.org
> Send Qgis-user mailing list submissions to
>  To subscribe or unsubscribe via the World Wide Web, visit
>          https://lists.osgeo.org/mailman/listinfo/qgis-user
>  or, via email, send a message with subject or body 'help' to
>  You can reach the person managing the list at
>          qgis-user-owner at lists.osgeo.org
>  When replying, please edit your Subject line so it is more specific
>  than "Re: Contents of Qgis-user digest..."
>  Today's Topics:
>    1. Re: Problem to open Raster files (Bernd Vogelgesang)
>    2. Re: Symbol lines every km, moving when changing scale or
>       moving map (Nyall Dawson)
>    3. Re: Problem to open Raster files (Nyall Dawson)
>    4. raster with distance values from a point (Fabio Falchi)
>  Message: 1
>  Date: Fri, 19 Feb 2021 21:42:38 +0100
>  From: Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
>  To: Cassia Pahim <cpahim at gmail.com>, qgis-user
>          <qgis-user at lists.osgeo.org>
>  Subject: Re: [Qgis-user] Problem to open Raster files
>  Message-ID: <1b52c0b6-2746-973d-9847-d09aaadc3b90 at gmx.de>
>  Content-Type: text/plain; charset=utf-8; format=flowed
>  seems this a ESRI File Geodatabase (sorry, left the ESRI stage 10 years
>  ago, so not sure).
>  As far as I know, rasters can't be exctracted from this with QGIS.
>  List of supported raster formats: https://gdal.org/drivers/raster/index.html
>  Am 19.02.21 um 21:00 schrieb Cassia Pahim:
>> They are in those formats
>>  .gdbindexes
>>  . gdbtable
>>  . horizon
>>  . gdbtablx
>>  . freelist
>>  . atx
>>  . spx
>>  Cassia
>>> Le 19 f?vr. 2021 ? 14:58, Bernd Vogelgesang
>>> <bernd.vogelgesang at gmx.de> a ?crit :
>>>  could you possibly share a little more details about what type of
>>> rasters you are dealing with? There is a bazillion of different
>>> raster formats!
>>>  Am 19.02.21 um 20:47 schrieb Cassia Pahim:
>>>> Hello,
>>>>  I am trying to create a map and I have 15 datasets that were
>>>> sent to me in a zip folder and I can?t open them into QGIS. When
>>>> using the icon ? add rater layer ? I get an error message telling
>>>> me the files are not valid or recognized. What should I do to be
>>>> able to work with those datasets ? Please note that I am using
>>>> macOS Catalina 10.15.7 and I have installed QGIS 3.16.
>>>>  I appreciate your help,
>>>>  Cassia
>>>>  _______________________________________________
>>>>  Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>  List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>>  Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>  Message: 2
>  Date: Sat, 20 Feb 2021 07:25:03 +1000
>  From: Nyall Dawson <nyall.dawson at gmail.com>
>  To: Andreas Neumann <a.neumann at carto.net>
>  Cc: Prud'homme J?r?mie <p.jeremie at gmail.com>, qgis-user
>  Subject: Re: [Qgis-user] Symbol lines every km, moving when changing
>          scale or moving map
>  Message-ID:
>          <CAB28AsioJzeQRb9qb_g7rK1YR5aC4BbGTt156dcjtJTnYen1cQ at mail.gmail.com>
>  Content-Type: text/plain; charset="UTF-8"
>  On Fri, 19 Feb 2021 at 23:00, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi J?r?mie,
>>  Ah good to hear!
>>  I'm not a big fan of this fact that line simplification is turned
>> on by default in QGIS. I believe that users should consciously turn
>> it on if they want it!
> I'd be interested to see some benchmarks of disabling vs enabling
>  simplification for the marker line symbol layer alone. If it's not too
>  expensive, we could skip it automatically for line marker symbol
>  layers (it makes a HUGE difference to the rendering speed for simple
>  line layers and other symbol layer types, but the intention is that
>  the results should be visually identical to no simplification).
>  Nyall
>> Your example shows that it can lead to confusion (understandably).
>>  Good that it works now. Note that you can override this setting on
>> a per layer base in the layer properties - so not all layers need
>> to have the same setting.
>>  Greetings,
>>  Andreas
>>  On 2021-02-19 13:40, Prud'homme J?r?mie wrote:
>>  Hi,
>>  I had simplification turned on, indeed...
>>  I deactivated it :
>>  - in the Options as you mention, so that it is deactivated for
>> newly added layers
>>  - in my layer options (Rendering properties)
>>  And it is ok now.
>>  It makes sense that if the line is simplified the distance vary !
>>  Thanks Andreas.
>>  J?r?mie.
>>  Le ven. 19 f?vr. 2021 ? 11:12, Andreas Neumann
>> <a.neumann at carto.net> a ?crit :
>>  Hi J?r?mie,
>>  Do you have geometry simplification turned off? See "Settings" -->
>> "Options" --> "Rendering" --> "Enable feature simplification ..."
>>  Make sure this is deactivated (I think it is enabled by default).
>>  Greetings,
>>  Andreas
>>  On 2021-02-19 11:05, Prud'homme J?r?mie wrote:
>>  Tested too fast :(
>>  Behavior is ok when zooming in, but still problems when zooming
>> out (whereas the entire feature is visible !).
>>  See here : https://www.zupimages.net/viewer.php?id=21/07/ehlo.gif
>>  Circles should follow the strokes generated with the tool "Points
>> along geometry".
>>  J?r?mie.
>>  Le ven. 19 f?vr. 2021 ? 10:03, Prud'homme J?r?mie
>> <p.jeremie at gmail.com> a ?crit :
>>  Hi,
>>  Thank you very much Nyall, this one was pretty well hidden.
>>  With clipping unchecked, behavior is as expected for my use case.
>>  J?r?mie.
>>  Le jeu. 18 f?vr. 2021 ? 23:29, Nyall Dawson
>> <nyall.dawson at gmail.com> a ?crit :
>>  On Wed, 13 Jan 2021 at 06:33, Prud'homme J?r?mie
>> <p.jeremie at gmail.com> wrote:
>>  Hi,
>>  I'm using QGIS 3.10.
>>  I tried to use only symbology to display a stroke every km along a road.
>>  The project CRS is 2154 (Lambert 93).
>>  When adding a ""symbol line" with an interval of 1000 map units
>> (meter for 2154) ? or 1000 meters at scale, same result ? I achieve
>> to display symbols every km.
>>  Problem is when I move the map or change scale, the symbols do not
>> always stay in place. They are sometimes misplaced.
>>  I've been told that problem can be that the first node of the line
>> is not always the reference to calculate the intervals.
>>  From the bottom of the symbol widget, click the "Advanced" button and
>>  uncheck "Clip features to canvas extent".
>>  Nyall
>>  You can find a GIF here that displays my problem :
>> https://zupimages.net/viewer.php?id=21/02/nvr2.gif
>>  Circles are symbols via Symbology.
>>  Strokes are symbos on points generated vith the tool "Points along
>> geometry".
>>  You can see that circles are not always at the same place as the strokes.
>>  Is it a "normal" behavior ?
>>  Anyway as a user I would expect that symbols are always generated
>> at the same place from the starting node.
>>  Thanks for your enlightments on this.
>>  J?r?mie.
>  Message: 3
>  Date: Sat, 20 Feb 2021 07:27:17 +1000
>  To: Bernd Vogelgesang <bernd.vogelgesang at gmx.de>
>  Cc: Cassia Pahim <cpahim at gmail.com>, qgis-user
>  Message-ID:
>          <CAB28AsjtkbLLiqy-O+LswVvgjt5Zf5crZ6YSKyk14HRSxbpUnQ at mail.gmail.com>
>  On Sat, 20 Feb 2021 at 06:43, Bernd Vogelgesang
>>  ago, so not sure).
> This is the ONLY way to use these data formats from open source
>  software: https://github.com/r-barnes/ArcRasterRescue
>  I've long been seeking a financial sponsor to fund development of a
>  GDAL driver for GDB raster layers, but to date have not had any luck.
>  If raster GDB support is important to your organisation, can you
>  please contact me off list to discuss sponsoring this development?
>  Thanks!
>  Nyall
>>  .gdbindexes
>>  . gdbtable
>>  . horizon
>>  . gdbtablx
>>  . freelist
>>  . atx
>>  . spx
>>  Cassia
>> raster formats!
>>  Hello,
>>  I am trying to create a map and I have 15 datasets that were sent
>> to me in a zip folder and I can?t open them into QGIS. When using
>> the icon ? add rater layer ? I get an error message telling me the
>> files are not valid or recognized. What should I do to be able to
>> work with those datasets ? Please note that I am using macOS
>>  Cassia
>  Message: 4
>  Date: Sat, 20 Feb 2021 17:04:14 +0000 (UTC)
>  From: Fabio Falchi <fabio_falchi at yahoo.it>
>  To: Qgis-user ML <qgis-user at lists.osgeo.org>
>  Subject: [Qgis-user] raster with distance values from a point
>  Message-ID: <622673810.907486.1613840654580 at mail.yahoo.com>
>  Content-Type: text/plain; charset="utf-8"
>  Dear all,
>  I need to speed up the process of obtaining rasters with distances
> from a single point in it. Manually I use this procedure:With a
> georeferenced raster in a UTM projection I use raster calculator to
> obtain a raster with all pixels set to zero. Then, with Serval
> plug-in, I manually set to 1 the value of the pixel in the wanted
> position (either by using a satellite overlay or by using a point
> vector layer with the appropriate coordinates). Then I use the
> proximity function under Raster>Analisys menu.I want to make this
> via the Graphical Modeler, in order to be able to make the process
> fast and skip the manual introduction with Serval plug-in. At the
> very least, I need a mode to put the value 1 in the pixel of the
> selected null raster in the position givel by lat-lon coordinates.
>  Thank you!Best,Fabio Falchi
>  USC - Universidade de Santiago de Compostela
>  ISTIL - Light Pollution Science and Technology Institute
>  -------------- next part --------------
>  An HTML attachment was scrubbed...
>  URL:
> <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210220/2eccf2ff/attachment-0001.html>
>  Subject: Digest Footer
>  End of Qgis-user Digest, Vol 180, Issue
> 52******************************************
----- Fim da mensagem de qgis-user-request at lists.osgeo.org -----
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210221/e4e63e4f/attachment-0001.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210221/e4e63e4f/attachment-0001.png>
