[Qgis-user] voronoi tool missing, what could have be wrong?
Hernán De Angelis variablestarlight at gmail.com
Fri Feb 26 06:44:26 PST 2021
Thank you for your response, Richard.
I am expecting to find it as you describe in the processing toolbox and
in Vector->Geometry Tools but it is not there. Also searching for
voronoi in the processing toolbox returns nothing.
Obviously, something is not quite OK in my installation. I will have to
keep searching.
/Hernán
On 2021-02-26 15:18, Richard Duivenvoorde wrote:
> Hi H,
> Where do you expect it to show up?
> If I search in 'processing'-algorithms in current master, it just shows up?
> Was it in a menu somewhere else earlier? (That is possible, maybe there was some cleanup of duplicate algo's??)
> Regards,
> On 2/26/21 2:56 PM, Hernán De Angelis wrote:
>> I built QGIS master from source last week. Everything went seemingly smooth and it apparently worked fine.
>> However, today I could not find the voronoi tool in the processing toolbox. A file search showed that the plugin seems to be installed:
>> # find /usr/local/share/ -name *voronoi*
>> /usr/local/share/qgis/grass/modules/v.voronoi.area.1.png
>> /usr/local/share/qgis/grass/modules/v.voronoi.area.2.svg
>> /usr/local/share/qgis/grass/modules/v.voronoi.area.qgm
>> /usr/local/share/qgis/grass/modules/v.voronoi.line.1.png
>> /usr/local/share/qgis/grass/modules/v.voronoi.line.2.svg
>> /usr/local/share/qgis/grass/modules/v.voronoi.line.qgm
>> /usr/local/share/qgis/python/plugins/processing/algs/grass7/description/v.voronoi.skeleton.txt
>> /usr/local/share/qgis/python/plugins/processing/algs/grass7/description/v.voronoi.txt
>> /usr/local/share/qgis/python/plugins/processing/algs/grass7/ext/v_voronoi.py
>> /usr/local/share/qgis/python/plugins/processing/algs/qgis/voronoi.py
>> Thought that perhaps the issue was not present in the newest 3.18 so I just built it from source. Again no problems, and yet the voronoi tool is still missing from the GUI but present in the location above.
>> What could be possibly wrong?
>> /H.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
