[Qgis-user] voronoi tool missing, what could have be wrong?
Richard Duivenvoorde
rdmailings at duif.net
Fri Feb 26 06:18:59 PST 2021
Hi H,
Where do you expect it to show up?
If I search in 'processing'-algorithms in current master, it just shows up?
Was it in a menu somewhere else earlier? (That is possible, maybe there was some cleanup of duplicate algo's??)
Regards,
On 2/26/21 2:56 PM, Hernán De Angelis wrote:
> I built QGIS master from source last week. Everything went seemingly smooth and it apparently worked fine.
> However, today I could not find the voronoi tool in the processing toolbox. A file search showed that the plugin seems to be installed:
> # find /usr/local/share/ -name *voronoi*
> /usr/local/share/qgis/grass/modules/v.voronoi.area.1.png
> /usr/local/share/qgis/grass/modules/v.voronoi.area.2.svg
> /usr/local/share/qgis/grass/modules/v.voronoi.area.qgm
> /usr/local/share/qgis/grass/modules/v.voronoi.line.1.png
> /usr/local/share/qgis/grass/modules/v.voronoi.line.2.svg
> /usr/local/share/qgis/grass/modules/v.voronoi.line.qgm
> /usr/local/share/qgis/python/plugins/processing/algs/grass7/description/v.voronoi.skeleton.txt
> /usr/local/share/qgis/python/plugins/processing/algs/grass7/description/v.voronoi.txt
> /usr/local/share/qgis/python/plugins/processing/algs/grass7/ext/v_voronoi.py
> /usr/local/share/qgis/python/plugins/processing/algs/qgis/voronoi.py
> Thought that perhaps the issue was not present in the newest 3.18 so I just built it from source. Again no problems, and yet the voronoi tool is still missing from the GUI but present in the location above.
> What could be possibly wrong?
> /H.
> Qgis-user mailing list
