[Qgis-user] QGIS 3.18.0 and QGIS 3.14.4 (LTR) packages released and OSGeo4W reboot
Jürgen E. Fischer jef at norbit.de
Sat Feb 27 04:50:55 PST 2021
Hi Andrea,
On Sat, 27. Feb 2021 at 00:27:22 -0700, Andrea Giudiceandrea wrote:
> why is the MSI installer size 1.1 GB, while the exe installer is only 391
> MB?
A lot of the dependencies are different, a newer compiler was used,
compression might be different.
But it probably just proj-data and numpy.  proj/share has ~580MB in the new
installer while its only 14MB in the old.  numpy with mkl is 600MB vs. numpy
w/o 45MB in the old.
After all proj-data blocked the update from PROJ 6 to 7 for a while since that
alone would have exceeded NSIS 2 GB limit.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210227/adcdf3b9/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210227/adcdf3b9/attachment.ksh>
