[Qgis-user] QGIS 3.18 how to load LiDAR
    Saber Razmjooei
    saber.razmjooei at lutraconsulting.co.uk
    Sat Feb 27 22:52:55 PST 2021
Hi All,
It is best if you follow the discussion in another thread about the new
QGIS installer.
Here is the latest stand-alone installer which I tested and worked well:
https://qgis.org/downloads/QGIS-OSGeo4W-3.18.0-1.msi
Kind regards
Saber
On Sat, 27 Feb 2021 at 23:02, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> I  have not research this much but I have the latest QGIS 3.18.0.1 with
> Pdal installed and I only see support ept.json files. Same with 3.19 dev.
> The post suggest there is and New OSGeo4W installer.  Perhaps that is the
> problem?
> The trouble shooting says (
> https://www.lutraconsulting.co.uk/blog/2021/02/15/qgis-point-cloud-windows/
> *Problem*: I am unable to add any LAS/LAZ point cloud file
> *Solution*: Ensure you have used the correct installer linked above.
> Development builds of QGIS in the ordinary OSGeo4W installer DO NOT include
> support for point clouds.
> That installer is found here.
> http://download.osgeo.org/osgeo4w/testing/
> Nicolas
> On 2021-02-27 7:05 a.m., Andrea Giudiceandrea wrote:
> Javier Soto wrote
> I have downloaded OSGEO installer following the instructions on this posthttps://www.lutraconsulting.co.uk/blog/2021/02/15/qgis-point-cloud-windows/
> but i have not managed to load point clouds in LAS or LAZ format.
> Hi Javier,
> most likely you need to install the PDAL library using the same OSGeo4W
> installer.
> Regards.
> Andrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing listQgis-user at lists.osgeo.org
> Nicolas Cadieuxhttps://gitlab.com/njacadieux
Saber Razmjooei
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210228/66c2be41/attachment.html>
