[Qgis-user] PDF Conversion with interactive layers
Charles Dixon-Paver
charles at kartoza.com
Fri Jan 1 14:59:37 PST 2021
This will be difficult to troubleshoot without more information. For
starters I would try ensuring that you have the latest version of QGIS
installed, and that all layers have valid CRS configuration.
There are a number of issues on GitHub which discuss this error (and
resolutions) in more detail:
https://github.com/qgis/QGIS/search?q=GeoPDF+could+not+create+print+device&type=issues
Otherwise, I think supplying more information on your environment details,
details on how to replicate the problem, and perhaps sharing a sample
project would help others come up with a suitable fix.
In the meantime I can also suggest starting a new user profile (Settings >>
User profiles >> New user profile) to eliminate any issues with plugins
etc, and to try testing the GeoPDF export on a new project with some test
data (like a local shapefile) to ensure that it's not a project specific or
data related issue.
On Sat, 2 Jan 2021 at 00:50, krishna Ayyala <ayyalakrishna at gmail.com> wrote:
> Charles,
> Thanks for the reply. I have followed the same steps as given in the link
> below. But, I am getting the following error.
> Regards.
> [image: image.png]
> On Fri, Jan 1, 2021 at 3:12 PM Charles Dixon-Paver <charles at kartoza.com>
> wrote:
>> Ensure that you check the "Create Geospatial PDF" in the export options
>> [1].
>> Note that not all PDF readers support this, but newer versions of the
>> FireFox web browser should be able to open the PDF file and let you check
>> that the layers are working properly.
>> [1] https://imgur.com/a/CCvtHks
>> On Sat, 2 Jan 2021 at 00:07, krishna Ayyala <ayyalakrishna at gmail.com>
>> wrote:
>>> Hello,
>>> I have a qgis map with 4 layers. I wish to export this map to PDF such
>>> that I can interactively turn-on and turn-off these layers. Can anyone help
>>> me with this?
>>> Regards
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210102/707fd95d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210102/707fd95d/attachment.png>
