[Qgis-user] question about statistical analysis and histograms
chris hermansen
clhermansen at gmail.com
Sat Jan 2 08:19:15 PST 2021
Azzurra and list,
On Sat, Jan 2, 2021, 08:07 Azzurra Lentini <azzurralentini at gmail.com> wrote:
> Hi to all,
> I am using Qgis 3.16.1.
> I have a shape file of polygons of different zones classified by type of
> vegetation (so each polygon has different type of vegetation and these
> polygons have different surface). Each type of vegetation has a code
> (string type: letters and numbers), so the field of type vegetation has
> data type string (text).
> I need to understand which kind of vegetation is more frequent (which type
> of vegetation occupies a greater areal extension) and I would like to do a
> histogram that shows the result.
I think you want the Vector Layer Histogram tool for this. I haven't used
it myself but from what I read it should do the job. I imagine you'll need
to add your area to the DBF.
https://gis.stackexchange.com/questions/352859/how-to-create-histogram-to-visualize-features-value-in-qgis-3
An alternative is to add the area to the DBF and import the DBF into your
favourite spreadsheet program. This would give you access to other
statistical tools.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210102/2ca9f54d/attachment.html>
