[Qgis-user] Creating the user profiles
Paul Wittle
paul.wittle at dorsetcouncil.gov.uk
Wed Jan 6 06:24:50 PST 2021
I have now worked out how to generate a user profile using python and I thought I'd reply to my own post in case it is of use to others.
I used:
profilePath = QStandardPaths.standardLocations(QStandardPaths.AppDataLocation)[0].replace("python","QGIS")
To get a path suitable for loading the QgsUserProfileManager. It seems that running standalone it defaults to /python on Windows but you may or may not need the replace statement. Once you have the path you just initiate the profileManager and then use createUserProfile:
QgsProfileManager = QgsUserProfileManager(profilePath + "\\profiles")
print(QgsProfileManager.rootLocation())
if not QgsProfileManager.profileExists("default"):
QgsProfileManager.createUserProfile("default")
print(versionName + " profile created")
This seems to do the trick and I run it before my other script to ensure that QGIS sets up a profile before the first load. That said; it doesn't include much of the profile itself so you might need to play with how you start a QgsApplication instance perhaps for that. Anyway it worked for what I needed and it might be helpful for others...perhaps.
Cheers,
Paul
This e-mail and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. It may contain unclassified but sensitive or protectively marked material and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All traffic may be subject to recording and/or monitoring in accordance with relevant legislation. Any views expressed in this message are those of the individual sender, except where the sender specifies and with authority, states them to be the views of Dorset Council. Dorset Council does not accept service of documents by fax or other electronic means. Virus checking: Whilst all reasonable steps have been taken to ensure that this electronic communication and its attachments whether encoded, encrypted or otherwise supplied are free from computer viruses, Dorset Council accepts no liability in respect of any loss, cost, damage or expense suffered as a result of accessing this message or any of its attachments. For information on how Dorset Council processes your information, please see www.dorsetcouncil.gov.uk/416433
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210106/7d704166/attachment.html>
