[Qgis-user] How do I clean up this geometry?
David Greenewalt dlg at sover.net
Sat Jan 9 08:06:03 PST 2021
I notice that the small polygon is a separate park. You could delete the
polygon. (or leave it as the separate area).   If the polys are to be
merged, you could manually edit the boundary (pull the vertices) so they
overlap completely, and then merge the polys.
If v.clean doesn't address all the problems and there are too many, you
could build the polys from lines. If the lines are correct, the polys
created from them will be clean.
David
On 1/8/2021 3:28 PM, qgis-user at stripfamily.net wrote:
> This linked
> <https://drive.google.com/file/d/1o1KthonUPSZGWp6QImS9btbj799Lv-om/view?usp=sharing>
> file, proclaimed.zip, is the boundary of the Santa Fe National Forest
> as supplied by the USFS.
> If you focus on this area
> There is some problematic geometry. If I do a dissolve I get this:
> If I remove the holes, I'm left with this bit of stray boundary:
> I then remove that with edit nodes. But the resulting polygon is still
> not clean  - if I try to use the field calculator to add the area
> (using $area), I get /null.
> /There is bad geometry that I'm not spotting, but how do I find it?
> The second linked
> <https://drive.google.com/file/d/1ul60p0rSdwKcmt6zUivSMIPQHXYc_rcT/view?usp=sharing>file,
> clean.zip, is the result of the steps above.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/dd80a6e6/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/dd80a6e6/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/dd80a6e6/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/dd80a6e6/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/dd80a6e6/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210109/dd80a6e6/attachment-0007.png>
