[Qgis-user] Training manual - 9.1.3. Configuring Additional Plugin Repositories
Alexandre Neto senhor.neto at gmail.com
Mon Jan 11 10:45:11 PST 2021
I think most of the plugins are now available on qgis official repository.
Alexandre Neto
A segunda, 11/01/2021, 17:48, Inna Nogeste <nogeste at outlook.com> escreveu:
> QGIS 3.16 – Faunalia plugins
> This step teaches how to configure a plugin respository from Faunalia
> https://docs.qgis.org/3.16/en/docs/training_manual/qgis_plugins/fetching_plugins.html#basic-fa-configuring-additional-plugin-repositories
> however I’m getting the following error message:
> “Error reading repository:Fanualia
> Server response is 200 OK, but doesn’t contain plugin metadata. This is
> most likely caused by a proxy or wrong repository URL. You can configure
> proxy settings in QGIS Options.”
> The URL in the training manual no longer exists and the plugins are
> located here instead:
> https://www.faunalia.eu/en/dev/plugins
> Does anyone (from Faunalia?) know what the URL should be or what needs to
> be edited in the Proxy settings for this to work? I’ll then be able to edit
> this step in the doucmentation GitHub with the correct info.
> Regards,
> Inna Nogeste
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210111/ff069dba/attachment.html>
