[Qgis-user] Training manual - 9.1.3. Configuring Additional Plugin Repositories
Alexandre Neto
senhor.neto at gmail.com
Fri Jan 15 00:13:07 PST 2021
If they are related to different sections or exercises then it's really
better to separate the issues, unless they are somehow related. For
example, if there is some missing file that is needed in several exercises.
Alexandre Neto
A quinta, 14/01/2021, 12:39, Inna Nogeste <nogeste at outlook.com> escreveu:
> Yes, I’ll create an issue, or perhaps issues, where I can’t find the
> solutions myself, for example missing/old URLs, and try to update
> documentation with 1 fix/day. There are alot of fixes and don’t know if
> they can all be listed and done within 1 issue?
> Regards,
> Inna
> Skickades från E-post <https://go.microsoft.com/fwlink/?LinkId=550986>
> för Windows 10
> *Från: *Alexandre Neto <senhor.neto at gmail.com>
> *Skickat: *den 13 januari 2021 14:05
> *Till: *Inna Nogeste <nogeste at outlook.com>
> *Kopia: *qgis-user <qgis-user at lists.osgeo.org>
> *Ämne: *Re: [Qgis-user] Training manual - 9.1.3. Configuring Additional
> Plugin Repositories
> If you can, please create an issue on github suggesting the corrections.
> A terça, 12/01/2021, 18:15, Inna Nogeste <nogeste at outlook.com> escreveu:
> I’ve seen that most of the plugins are in the repository, this is an
> example in the tutorial which could be deleted, else include a source which
> has plugins not included in the repository if it is important to show this
> stage.
> Regards,
> Inna Nogeste
> *Skickat: *den 11 januari 2021 19:45
> Plugin Repositories
> I think most of the plugins are now available on qgis official repository.
> Alexandre Neto
> A segunda, 11/01/2021, 17:48, Inna Nogeste <nogeste at outlook.com> escreveu:
> QGIS 3.16 – Faunalia plugins
> This step teaches how to configure a plugin respository from Faunalia
> https://docs.qgis.org/3.16/en/docs/training_manual/qgis_plugins/fetching_plugins.html#basic-fa-configuring-additional-plugin-repositories
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.qgis.org%2F3.16%2Fen%2Fdocs%2Ftraining_manual%2Fqgis_plugins%2Ffetching_plugins.html%23basic-fa-configuring-additional-plugin-repositories&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106205590%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=HW6Zh1MR8jpfTKH4OrsWGyeZ%2FxAJRXC0U7rVIkz1ZaE%3D&reserved=0>
> however I’m getting the following error message:
> “Error reading repository:Fanualia
> Server response is 200 OK, but doesn’t contain plugin metadata. This is
> most likely caused by a proxy or wrong repository URL. You can configure
> proxy settings in QGIS Options.”
> The URL in the training manual no longer exists and the plugins are
> located here instead:
> https://www.faunalia.eu/en/dev/plugins
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.faunalia.eu%2Fen%2Fdev%2Fplugins&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106215584%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=ivKJoRhY%2B0ff3oyYUN207V%2B%2FFMerOq90bPAraL0JkTs%3D&reserved=0>
> Does anyone (from Faunalia?) know what the URL should be or what needs to
> be edited in the Proxy settings for this to work? I’ll then be able to edit
> this step in the doucmentation GitHub with the correct info.
> Regards,
> Inna Nogeste
> Qgis-user mailing list
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106215584%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=N5CsMY8Cq0n2jKq9KO67QGhSWZzKSh7KbYvjE2aDd%2Bw%3D&reserved=0>
> <https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user&data=04%7C01%7C%7C488d15a35c934390b81f08d8b7c3db2c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637461399106225581%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=UkW6alR%2FlHHSAWwonmSszftpRlIcgO3yceDTNlporeQ%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210115/e96b91ab/attachment.html>
