[Qgis-user] Failure to open .laz file in QGIS
    MikeNepal
    mikko.niipala at gmail.com
    Thu Jan 21 01:48:53 PST 2021
Hello,
Not sure if this is the right way or place to ask help for this specific
problem, but can't solve the issue why I fail to open a .laz-file which I
have downloaded from National land survey agency. I am using QGIS 3.16 on
Windows and have activated LAStools plugin. When trying to open the .laz on
Processing tools --> lastools --> fileview I get the following result:
{ 'ADDITIONAL_OPTIONS' : '', 'COLORING' : 0, 'GUI' : False, 'INPUT_LASLAZ' :
'C:\\M4311C3.laz', 'POINTS' : 5000000, 'SIZE' : 0, 'VERBOSE' : False }
LAStools command line
C:\LAStools\bin\lasview -i "C:\M4311C3.laz" -points 5000000
LAStools console output
File "C:/Users/Mikko
Niipala/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\LAStools\LAStools\lasview.py",
line 67, in processAlgorithm
LAStoolsUtils.runLAStools(commands, feedback)
Niipala/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\LAStools\LAStoolsUtils.py",
line 61, in runLAStools
feedback.pushConsoleInfo(output.decode("utf-8"))
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x84 in position 1:
invalid start byte
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
