[Qgis-user] GTiff compression issues
Sebastian Gutwein
bas at rdgland.com
Thu Jan 21 05:32:00 PST 2021
Not my area of expertise but my first suspect would be the alpha channel
(the A in RGBA or transparency). JPEG doesn’t support an alpha channel. You
might try png or jpeg 2000 as an alternative.
On Thu, Jan 21, 2021 at 2:12 AM Yury <yury.zammit at gmail.com> wrote:
> Hi,
> I am using QGIS to try and compress hi-res drone imagery. I am using GDAL
> tools, such as 'Clip Raster by Extent' . In the command line parameters I
> am adding the following:
> -co COMPRESS=JPEG -co TILED=YES --config GDAL_TIFF_INTERNAL_MASK YES.
> The original image is RGBA.
> Compression is significant (which is what I need) and visually there is
> not much of a difference. However, when zooming further in (1:200), I
> noticed that some raster cells have turned white. When inspecting, it
> appears that the compression is changing the data of one or more of the
> bands to nodata. How can this be resolved?
> I am using QGIS 3.10.8
> Thanks
> Yury Zammit
> Qgis-user mailing list
Sent from a phone. Amazing! But possibly garbled. Sebastian Gutwein
Regenerative Design Group 1 Chevalier Ave Greenfield MA Bas at rdgland.com
(631) 241-1018
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210121/6d8b3d22/attachment.html>
