[Qgis-user] Missing plugins in version 3.20
Charles Dixon-Paver charles at kartoza.com
Tue Jul 6 14:58:24 PDT 2021
It seems that QGIS 3.20 is unable to access python correctly. It is
possible that this is an ENV/ Path error that may be resolved by launching
QGIS from a relevant batch file, such as C:\OSGeo4W\bin\qgis.bat (or
similar depending on your installation configuration)
Are you using the "new" OSGeo4W installer? If not and you attempted to
upgrade from the old installer it could be causing the issue.
There was an update to OSGeo4W for the latest release that is not really
backwards compatible. The current recommendation is to uninstall QGIS/
remove the historic OSGeo4W installation directory (or rename it), download
the latest installer from QGIS.org [1] and install a new instance of QGIS
from there.
If you are using the LTR (stable release), then using the existing
installer to upgrade should be fine, but you likely won't be able to use
3.20 correctly. There is more information on the downloads page related to
this.
[1] https://www.qgis.org/en/site/forusers/download.html
On Tue, 6 Jul 2021 at 23:17, Pat Brown <mistyhaven at gmail.com> wrote:
> Hi Charles,
>    Tried with a new user profile and I get the same result. The attached
> pics show what is displayed at each tab of the plugin manager
> On Tue, 6 Jul 2021 at 22:55, Charles Dixon-Paver <charles at kartoza.com>
> wrote:
>> Hi there,
>> Have you tried to access the plugins with a fresh user profile?
>> Also, the plugins manager has a settings tab. Can you give some more
>> information on the current configuration settings, such as the configured
>> plugin repository URL?
>> On Tue, 6 Jul 2021 at 22:49, Pat Brown <mistyhaven at gmail.com> wrote:
>>> Hi
>>>     I asked this a few days ago and I am wondering if perhaps no-one
>>> else has come across this problem.
>>> "I have installed the above version but it only shows 4 plug-ins.
>>> Whether I click on ALL or INSTALLED it still only shows 4. If I go back to
>>> 3.18 it works fine. Can anybody suggest a possible solution?"
>>> I uninstalled all versions on my PC and reinstalled 3.20 but still have
>>> the same problem. I then uninstalled 3.20 and reinstalled 3.18 and the
>>> plugins work fine.
>>> Is there maybe a way to contact the developers to see if I can find a
>>> cause of my problem?
>>> Thanks,
>>> Pat
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210706/17283b5e/attachment.html>
