[Qgis-user] Problem using Model Inputs variable in an Select by expression in the model Designer
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Wed Jul  7 22:17:25 PDT 2021
I am creating a model that fixes Network files before they are used in
the QGIS Network analysis (Shortest path) tools.
This is my work flow:
 1. Create a "Length" field (value) and calculate $length in the field
    calculator
 2. Split the Multipart lines into Singlepart lines
 3. Create a "Length*2*" field (value) and calculate $length in the
    field calculator
 4. Select by expression Length != Length2.  This basically gives me a
    selection of line that have been modified by the Multipart to
    Singlepart algorithm. (I get 8 results)
This works well
The problem is when I create and Input String to let the user create a
"Length" field.  This become a variable called @NamelengthField. My work
flow become:
 1. User input "Length" in the Model input. (@NamelengthField)
 2. Create a "Length" field using  @NamelengthField (as pre-calculated
    value) and calculate $length in the field calculator: This is OK
 3. Split the Multipart lines into Singlepart lines: This is OK
 4. Create a "Length2" field using  @NamelengthField ||'2'  (as
    pre-calculated value) and calculate $length in the field calculator:
    This is OK this field (Length2) is created and calculated properly.
 5. I get stuck  when I try Select by expression using @NamelengthField
    != @NamelengthField || '2' (as pre-calculated value) (I get all
    lines back) and the test does not work.
I tried stuff like
@NamelengthField != (@NamelengthField || '2')
'@NamelengthField != @NamelengthField || '2''
"@NamelengthField != @NamelengthField || '2'"
"@NamelengthField"|| !=|| "@NamelengthField || '2'"
Even simple @NamelengthField = 5.286365157529550 (which should extract
exactly one value).
Any ideas?
Nicolas
QGIS 3.18.2 on Windows 10
Nicolas Cadieux
https://gitlab.com/njacadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210708/afe6966c/attachment.html>
