[Qgis-user] points to lines - direction and lenghts attribute table
C Hamilton
adenaculture at gmail.com
Tue Jul 13 06:09:08 PDT 2021
If you already have a point geometry with a length and direction then I
would use the ShapeTools <https://plugins.qgis.org/plugins/shapetools/>plugin
and would run "Vector->Shape Tools->Create shapes->Create line of bearing."
You can select your input layer and then select the attribute that contains
the length and the attribute that contains the direction.
If you need to create a point layer from coordinates from the attribute
table, then I would first use the Lat Lon Tools
<https://plugins.qgis.org/plugins/latlontools/> plugin and run
"Plugins->Lat Lon Tools->Conversions->Fields to point layer" and then use
the ShapeTools plugin.
Best wishes,
Calvin
On Tue, Jul 13, 2021 at 8:40 AM Azzurra Lentini <azzurralentini at gmail.com>
wrote:
> Hi to all, can you suggest to me how to generate lines from points
> (centroids) giving to these lines certains lengths and directions from the
> attribute table?
> Thanks Azzurra
> Adjunct Professor University "Roma Tre"
> Gis Applied for Environmental studies
> Risk modelling & Hydrogeology
> Consultant DFID-UK, United Nations, EU projects
> AZZURRA LENTINI
> Italy Mobile Tel.: **(39) 338 24 40 676
> SKYPE azzurrahydro
> *azzurralentini at gmail.com <azzurralentini at gmail.com>*
> *azzurra.lentini at uniroma3.it <azzurra.lentini at uniroma3.it> *
> *Par respect pour l'environnement,*
> *n'imprimez ce mail qu'en cas d'absolue nécessité*
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210713/9835fdcc/attachment.html>
