[Qgis-user] Import Kmz without losing the symbology
    Nyall Dawson
    nyall.dawson at gmail.com
    Wed Jul 14 22:11:03 PDT 2021
On Wed, 14 Jul 2021 at 19:28, Stefan Giese (WhereGroup)
<stefan.giese at wheregroup.com> wrote:
> unfortunally I didn't read the whole feature description in the changelog, it says  "...Currently only supports line symbol conversion, but point and polygon symbol support is under development...." may be that is the reason...
The changelog is incorrect here -- it's supported for all geometry
types, including point and polygon.
Likely the issue here is in GDAL not supporting the particular styling
format used in this specific kmz, but you'd need to share the data in
order to verify this.
Nyall
> Am 14.07.2021 um 11:21 schrieb krishna Ayyala:
> Stefan,
> Thanks a lot for your reply. I have upgraded my QGIS version to 3.20 and added the kmz file on to my map. Still I am getting the plain rectangle. I am not getting the symbology as it is in the original Kmz.Actually my Kmz has circles with colors inside it.
> Regards.
> On Tue, Jul 13, 2021 at 11:48 PM Stefan Giese (WhereGroup) <stefan.giese at wheregroup.com> wrote:
>> Hi,
>> depends on the QGIS Version. QGIS 3.20 can render embedded styles from kml/kmz (https://www.qgis.org/en/site/forusers/visualchangelog320/index.html#feature-new-embedded-styling-renderer-with-ogr-feature-styles-support).
>> regards
>> Stefan
>> Am 14.07.2021 um 04:52 schrieb krishna Ayyala:
>> Hello,
>> I have a kmz. The Kmz has circles with different colors in it. When I add the kmz to QGIS map, I am getting a plain rectangle. How to add this kmz to the map by preserving all the symbology and the colors.
>> Regards
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Mit freundlichen Grüßen
>> Stefan Giese
>> Projektleiter/Consultant
>> Aufbau von Geodateninfrastrukturen mit Open-Source-Software
>> FOSS Academy 5 Tage-Kompaktkurs „Sommerschule 2021“
>> Jetzt anmelden: https://foss-academy.com/kompaktkurse/
>> WhereGroup GmbH
>> Schwimmbadstr. 2
>> 79100 Freiburg
>> Germany
>> Fon: +49 (0)761 / 519 102 - 61
>> Fax: +49 (0)761 / 519 102 - 11
>> www.wheregroup.com
>> Geschäftsführer:
>> Olaf Knopp, Peter Stamm
>> Amtsgericht Bonn, HRB 9885
> Stefan Giese
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> www.wheregroup.com
> Geschäftsführer:
