[Qgis-user] Multiplicity in Model Input (Layers)
Andreas Neumann
a.neumann at carto.net
Thu Jul 15 01:20:18 PDT 2021
Hi Andrew,
Yes, the "Multiple Input" input type should do the trick. After that
input parameter you'd normally have to merge all input files/layers into
one. The "Merge vector layers" transformer seems to be one of the very
few (or the only) algorithm that seems to accept multi-layer input.
Of course the "Merge vector layers" algorithm expects the layer to have
the same structure, otherwise you'll have some really funny and
unpredictable results.
Greetings and hope this helps,
Andreas
On 2021-07-15 09:46, Alexandre Neto wrote:
> Hi Andrew,
> You need to use the "multiple input" input type.
> Best regards
> Alexandre Neto
> User support
> www.qcooperative.net [1]
> A quinta, 15/07/2021, 08:33, Andrew Hughes <ahhughes at gmail.com>
> escreveu:
>> Hi All,
>> Could any provide some advice as I am new to this and need some
>> guidance please.
>> My model needs to consume data from MULTIPLE Esri rest layers. I can
>> do this for on a 1:1 basis where I manually add 1 input vector layer
>> per esri rest layer. But that's not great. This model is not easily
>> reusable, as the number of layers always varies.
>> Q1: The merge processor takes in a multi-layers on a single input -
>> but I can't see how this is done in a model. Can anyone please
>> explain?
>> Q2: Is is possible for me to write a python processor that doesn't
>> require any project layers as input, it can create the layers itself
>> (in code/config) and feed them into the merge processor and output the
>> single merged layer?
>> Thanks in advance
>> Andrew
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Links:
[1] http://www.qcooperative.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210715/9e59ff69/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210715/9e59ff69/attachment-0001.png>
