[Qgis-user] Converting from degree decimal into degree-minutes-secondes
jean Lukusa
lukusam at gmail.com
Thu Jul 22 14:50:23 PDT 2021
Many thanks.
Jean Lukusa
B.Sc. Geology
Trained on Jorc Code
GIS Operator
+243812156128
Le jeu. 22 juil. 2021 à 22:30, Charles Dixon-Paver <charles at kartoza.com> a
écrit :
> QGIS Expression builder has a to_dms function available.
> For example, you could use the field calculator to update a text field
> like so:
> to_dms( "x_field" ,'x', 3) || ', ' || to_dms( "y_field" ,'y', 3)
> Should yield results such as the following:
> x_field: 23.3978700906344
> y_field : -30.810918277945603
> dms_field: 23°23′52.332″, -30°48′39.306″
> You can get point positions also using QGIS expressions and the $x and $y
> parameters
> Regards
> On Thu, 22 Jul 2021 at 22:59, jean Lukusa <lukusam at gmail.com> wrote:
>> Hi all.
>> Would you help me how to convert longitude and latitude coordinates of a
>> point from decimal degree into degree-minutes-secondes directly in an
>> attribute table of shapefile ?
>> Jean Lukusa
>> B.Sc. Geology
>> GIS Operator
>> +243812156128
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210722/cb93e3ee/attachment.html>
