[Qgis-user] Bathymetry data area coverage calculator
Peters
petersinmorocco at gmail.com
Sat Jul 31 14:51:51 PDT 2021
Thanks, I'll check it out.
On Sat, Jul 31, 2021, 20:42 Charles Dixon-Paver <charles at kartoza.com> wrote:
> The raster calculator is a tool for raster analysis which doesn't quite
> suit your needs as I understand them. If you want to learn how to use the
> raster calculator there is a tutorial available on the QGIS changelog
> lessons [1].
> That blog post I linked to before is likely the most effective or
> performant option for you, and it contains links to scripts that will
> perform the analysis for you.
> As an alternative, I have created a simple model which steps through the
> vectorization process of reclassifying a raster and calculating the area
> [2]. The data I used to test the model was the SRTM tile used in the
> previously mentioned lesson [1], so you can introspect it and copy the
> logic or tweak it as needed. I did a session on using the modeler for the
> last Open Day [3] so you can get familiar with them if you aren't already.
> [1] https://changelog.qgis.org/en/qgis/lesson/raster-16/detail/51/?q=7.2
> [2]
> https://github.com/zacharlie/effective-dollop/blob/main/qgis-models/raster_area_calculation_example.model3
> [3] https://github.com/qgis/QGIS/wiki/QOD-July-2021
> On Sat, 31 Jul 2021 at 20:29, Peters <petersinmorocco at gmail.com> wrote:
>> Very helpful. Yes, our data is raster. I saw a calculator tool in the
>> raster toolbar but haven't been able to figure it out or if it's pertinent.
>> On Sat, Jul 31, 2021, 19:01 Charles Dixon-Paver <charles at kartoza.com>
>> wrote:
>>> I think you will need to provide more information on describing the
>>> input data, as well as how exactly you wish to process it.
>>> If your coverage data is vector areas you should be able to simply use
>>> the aggregate processing tool using $area as the source expression and
>>> stipulate a sum aggregate function. You may also use the grouping
>>> function to filter the results as needed using an expression.
>>> This would provide the area based on map units, so you would need to
>>> reproject your data into a relevant metric projection before performing the
>>> aggregation. A single hectare is simply 10000 m² so simple arithmetic will
>>> allow you to convert metric areas to hectares.
>>> If your data is another vector data type such as point clouds, you may
>>> need to buffer or calculate a minimum bounding geometry or convex hull
>>> before processing it as the area calculation will of course only work on
>>> area features.
>>> For raster data, the total area would be a simple calculation of the
>>> extents, or the dimensions and cell size. Again, you may need to reproject
>>> the data for it to be available in meters.
>>> If, however, you wish to segregate raster data based on cell value, you
>>> may want to recode and vectorize the data, or alternatively perform some
>>> form of custom analysis as described in the following article:
>>> https://www.kartoza.com/en/blog/calculating-area-of-rasters-in-qgis/
>>> Regards
>>> On Sat, 31 Jul 2021 at 19:15, Peters <petersinmorocco at gmail.com> wrote:
>>>> Does anyone know of such a calculator as a plugin or option? At the
>>>> moment I am using QGIS app. Our client has asked for area coverage in sq.
>>>> mtrs or hectares. Appreciate any info you may have.
>>>> *regards,*
>>>> *K. Peters*
>>>> *cell: (Morocco) +212.671.218606*
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210731/def250bb/attachment.html>
