[Qgis-user] Editing attributes in embedded forms
    Andreas Neumann
    a.neumann at carto.net
    Tue Jun  1 01:09:57 PDT 2021
Hi Pekka,
Have you enabled the  transaction mode in your project?
See menu "Project" --> "Properties" --> "Data Sources".
I usually enable all three check boxes:
- Automatically create transaction groups where possible
- Evaluate default values on provider side
- Trust project when data source has no metadata
The transaction mode allows to edit all layers from the same data base
connection (needs identical db connection string and credentials) and -
together with "evaluate default values on provider side" - immediately
retrieves primary keys from the DB, so that you can link objects
immediately, without having to save first.
Greetings,
Andreas
On 2021-06-01 09:55, Pekka Sarkola wrote:
> Hi folks!
> I have a problem editing feature attributes in embedded forms. Data is
> stored in PostGIS and I have a simple 1:1 relationship with the
> geometry table and an additional attribute table. QGIS version is
> 3.18.3 on Ubuntu.
> I have created a custom form with a drag-and-drop designer. I can edit
> additional attribute table attributes in embedded form, but those edits
> are not stored anywhere. I have to open a separate form and then edit
> attribute values of the related attribute table. This is quite annoying
> for the end user.
> Any suggestions? Or should I write a better description to the Github?
> Rgs,
> Pekka
> Pekka Sarkola
> Gispo Oy
> pekka.sarkola at gispo.fi   - GSM +358 40 725 2042
> www.gispo.fi [1] - www.paikkatieto.com [2]
> Qgis-user mailing list
Links:
[1] http://www.gispo.fi/
[2] http://www.paikkatieto.com/
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210601/7624c94f/attachment.html>
