[Qgis-user] Rename column
    Ujaval Gandhi
    ujaval at spatialthoughts.com
    Tue Jun  1 05:38:40 PDT 2021
You can also use the 'Refactor Fields' algorithm from the Processing
Toolbox - which can not only rename the fields but also change the order
and types as well.
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/>  [image:
Twitter icon] <https://twitter.com/spatialthoughts>
On Tue, Jun 1, 2021 at 3:35 PM Matt Boyd <mattslists at gmail.com> wrote:
> You can rename columns (or fields) in the layer properties (need to
> have editting turned on)
> In the field calculator, sometimes I have issues with the data type
> and "fieldname" doesn't work so well but if I do "1*fieldname" it
> does.
> On Tue, Jun 1, 2021 at 7:31 PM Ursula Heinze <ursula.heinze at online.de>
> wrote:
> > Hello,
> > I have a little problem with the field calculator. I want to rename a
> column, and I don´t find any way to do it.
> > Now I tried to copy the field values in a new column with the right
> name, and am also not successful. Has anybody an idea for me, how to solve
> the problem? Many thanks in advance!
> > Ursula Heinze
> > Gesendet von Mail für Windows 10
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210601/af5dade1/attachment.html>
