[Qgis-user] Rename column
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Tue Jun 1 07:27:13 PDT 2021
There should be a method renameAttribute as part of QgsVectorLayer class.
You can do something like that:
layer = iface.activeLayer()
for field in layer.pendingFields():
if field.name() == 'old':
with edit(layer):
idx = layer.fieldNameIndex(field.name())
layer.renameAttribute(idx, 'new')
Good luck!
Marian
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Ursula Heinze
Sent: June 1, 2021 5:26 AM
To: Qgis-user at lists.osgeo.org
Subject: [EXT] [Qgis-user] Rename column
CAUTION: This email originated from outside of the organization. If you do not recognize the sender or you are not certain the content is safe, then do not click on any links or open any attachments.
AVERTISSEMENT : Ce courriel provient d’une source externe à l’organisation. Si vous ne reconnaissez pas l’expéditeur ou si vous doutez de la sécurité du contenu, ne cliquez sur aucun lien et n’ouvrez aucune pièce jointe.
Hello,
I have a little problem with the field calculator. I want to rename a column, and I don´t find any way to do it.
Now I tried to copy the field values in a new column with the right name, and am also not successful. Has anybody an idea for me, how to solve the problem? Many thanks in advance!
Ursula Heinze
Gesendet von Mail<https://urldefense.com/v3/__https:/go.microsoft.com/fwlink/?LinkId=550986__;!!P0kg3YazkQ!W94jRKLCVMrbhztEtw9jiDUPiECzoEscG5JxdIsa3_vpvGZuh4v0QGxdDJLtJD0Tmg$> für Windows 10
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210601/2d9e6ec0/attachment-0001.html>
