[Qgis-user] Rename column
    Richard McDonnell
    richard.mcdonnell at opw.ie
    Tue Jun  1 08:03:03 PDT 2021
In relation to editing Tables, reordering, remaning etc.. can be carried out using Refactor fields, which can be found in the Processing Toolbox
Regards,
Richard.
Richard McDonnell MSc GIS, FME Certified Professional
FRM Data Management
Oifig na nOibreacha Poiblí
Office of Public Works
Sráid Jonathan Swift, Baile Átha Troim, Co na Mí, C15 NX36
Jonathan Swift Street, Trim, Co Meath, C15 NX36
M +353 87 688 5964 T +353 46 942 2409
https://gov.ie/opw
To send me files larger than 30MB, please use the link below https://filetransfer.opw.ie/filedrop/richard.mcdonnell@opw.ie
Email Disclaimer: https://www.gov.ie/en/organisation-information/439daf-email-disclaimer/
https://www.opw.ie
Email Disclaimer: https://www.opw.ie/en/disclaimer/
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Tudorache, Marian
Sent: 01 June 2021 15:27
To: Ursula Heinze <ursula.heinze at online.de>; Qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Rename column
There should be a method renameAttribute as part of QgsVectorLayer class.
You can do something like that:
layer = iface.activeLayer()
for field in layer.pendingFields():
    if field.name() == 'old':
        with edit(layer):
            idx = layer.fieldNameIndex(field.name())
            layer.renameAttribute(idx, 'new')
Good luck!
Marian
From: Qgis-user <qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>> On Behalf Of Ursula Heinze
Sent: June 1, 2021 5:26 AM
To: Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
Subject: [EXT] [Qgis-user] Rename column
CAUTION: This email originated from outside of the organization. If you do not recognize the sender or you are not certain the content is safe, then do not click on any links or open any attachments.
AVERTISSEMENT : Ce courriel provient d’une source externe à l’organisation. Si vous ne reconnaissez pas l’expéditeur ou si vous doutez de la sécurité du contenu, ne cliquez sur aucun lien et n’ouvrez aucune pièce jointe.
Hello,
I have a little problem with the field calculator. I want to rename a column, and I don´t find any way to do it.
Now I tried to copy the field values in a new column with the right name, and am also not successful. Has anybody an idea for me, how to solve the problem? Many thanks in advance!
Ursula Heinze
Gesendet von Mail<https://urldefense.com/v3/__https:/go.microsoft.com/fwlink/?LinkId=550986__;!!P0kg3YazkQ!W94jRKLCVMrbhztEtw9jiDUPiECzoEscG5JxdIsa3_vpvGZuh4v0QGxdDJLtJD0Tmg$> für Windows 10
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
Please note that the existing 01-6476XXX / 046-9426XXX numbering ranges will no longer be available after 30th April 2021.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210601/665197f4/attachment.html>
