[Qgis-user] Visibility of items in SQL Database
Johanna Botman
johannab at melton.vic.gov.au
Mon Jun 7 23:39:33 PDT 2021
I have a situation where I have two SQL databases and I have to move data from one to the other. Always the same direction from DB1 to DB2
My issue is that the items show in some tables in DB1 but do not display in QGIS.
I can select from the table, but I can't select items on the QGIS canvas
I can cut and paste from DB1 to DB2 and the items display in DB2.
I can manually create an item in an affected table in DB1 and it will display.
When I hover with my Add [polygon/line/point] tool, the square to show where the vertices (for snapping) are displayed as I move my cursor over them.
When I run the Validate Geometry tool, the results are that I have valid geometry and those layers are displayed.
In SQL server manager I can see the spatial results for those tables in DB1.
Projections are the same for each DB
There are no Layer Scale Visibility settings in play for either DB
It does not affect all tables in DB1.
Can anyone suggest some further troubleshooting strategies?
Johanna Botman
Assets / GIS Officer - Melton City Council
The information in this message is privileged and confidential, intended only for the use of the individual or entity named above. If you are not the intended recipient you are hereby notified to delete the message and that any dissemination, copying or use of its content is strictly prohibited. If you have received this message in error please notify the Melton City Council.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210608/5beb4952/attachment.html>
