[Qgis-user] Visibility of items in SQL Database
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue Jun 8 03:21:05 PDT 2021
Hi Johanna -
I suspect, you have some symbology issues with the layer/table from DB1
Try to change the symbology from "whatever it is now" to a "Single
symbol" for the DB1 layer and check if your missing objects appear
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 08-06-2021 kl. 08:39 skrev Johanna Botman:
> Hi,
> I have a situation where I have two SQL databases and I have to move
> data from one to the other. Always the same direction from DB1 to DB2
> My issue is that the items show in some tables in DB1 but do not
> display in QGIS.
> I can select from the table, but I can’t select items on the QGIS canvas
> I can cut and paste from DB1 to DB2 and the items display in DB2.
> I can manually create an item in an affected table in DB1 and it will
> display.
> When I hover with my Add [polygon/line/point] tool, the square to show
> where the vertices (for snapping) are displayed as I move my cursor
> over them.
> When I run the Validate Geometry tool, the results are that I have
> valid geometry and those layers are displayed.
> In SQL server manager I can see the spatial results for those tables
> in DB1.
> Projections are the same for each DB
> There are no Layer Scale Visibility settings in play for either DB
> It does not affect all tables in DB1.
> Can anyone suggest some further troubleshooting strategies?
> *Johanna Botman*
> Assets / GIS Officer – Melton City Council
> The information in this message is privileged and confidential,
> intended only for the use of the individual or entity named above. If
> you are not the intended recipient you are hereby notified to delete
> the message and that any dissemination, copying or use of its content
> is strictly prohibited. If you have received this message in error
> please notify the Melton City Council.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210608/d7d5543a/attachment.html>
