[Qgis-user] Compiling messages Qgis 3.18.3
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Jun 10 23:52:04 PDT 2021
Saulteau Don wrote
> The patch resolved almost all of them! It's left a single CRS that
> couldn't
> be:
> Could not execute: INSERT INTO tbl_srs(srs_id,
> description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated)
> VALUES (63
> 321, 'Timbalai 1948 / RSO Sarawak LSD (m)','omerc','omerc','+proj=omerc
> +no_uoff +lat_0=4 +lonc=115 +alpha=53.3158204722222
> +gamma=53.1301023611111
> +k=0.99984
> +x_0=2000000 +y_0=5000000 +ellps=evrstSS +towgs84=-679,669,-48,0,0,0,0
> +units=m +no_defs',520003321,'EPSG','29874',0,0) [UNIQUE constraint
> failed:
> tbl_srs.srs_
> id/UNIQUE constraint failed: tbl_srs.srs_id]
Hi Saulteau,
thank you very much for testing the patch and reporting the remaining error.
The error is related to another issue for which I've submitted now a Pull
Request https://github.com/qgis/QGIS/pull/43694
Could you test it and check if the "Timbalai 1948 / RSO Sarawak LSD (m)",
EPSG:29874, crs is then available in QGIS?
Regards.
Andrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
