[Qgis-user] Compiling messages Qgis 3.18.3
    Richard Duivenvoorde
    rdmailings at duif.net
    Fri Jun 11 00:51:10 PDT 2021
Thanks Andrea, for diving into this..
I've seen this for a long time already, but really always have thought this errors/warning were trivial/byproducts of installer.
I'll check better next time
Richard
On 6/11/21 8:52 AM, Andrea Giudiceandrea wrote:
> Saulteau Don wrote
>> The patch resolved almost all of them! It's left a single CRS that
>> couldn't
>> be:
>> Could not execute: INSERT INTO tbl_srs(srs_id,
>> description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated)
>> VALUES (63
>> 321, 'Timbalai 1948 / RSO Sarawak LSD (m)','omerc','omerc','+proj=omerc
>> +no_uoff +lat_0=4 +lonc=115 +alpha=53.3158204722222
>> +gamma=53.1301023611111
>> +k=0.99984
>> +x_0=2000000 +y_0=5000000 +ellps=evrstSS +towgs84=-679,669,-48,0,0,0,0
>> +units=m +no_defs',520003321,'EPSG','29874',0,0) [UNIQUE constraint
>> failed:
>> tbl_srs.srs_
>> id/UNIQUE constraint failed: tbl_srs.srs_id]
> Hi Saulteau,
> thank you very much for testing the patch and reporting the remaining error.
> The error is related to another issue for which I've submitted now a Pull
> Request https://github.com/qgis/QGIS/pull/43694
> Could you test it and check if the "Timbalai 1948 / RSO Sarawak LSD (m)",
> EPSG:29874, crs is then available in QGIS?
> Regards.
> Andrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
