[Qgis-user] Compiling messages Qgis 3.18.3
    APM
    apschwimmer at apmland.de
    Fri Jun 11 00:24:37 PDT 2021
Hello Saulteau,
I'm unsure, if I understand your information right.
1. Go to the issue that Andrea referenced at....   > ok
2. copy the patch link with the clipboard button.....
I think this is the button on the right side beneath "Verified". If I
press it   in Firefox
I have "4036e3d6ae71ffefc48a22295e338f59502949bb" in the browsers clipboard.
So I copy and paste the file directly and stored it as 'srs-fix.diff':
If I use the command
patch -Np1 -i /home/user/tmp/srs-fix.diff
I get the message:
user at debian:~/src/qgis/cpp/QGIS/src$ patch -Np1 -i
can't find file to patch at input line 5
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/src/core/proj/qgscoordinatereferencesystem.cpp
b/src/core/proj/qgscoordinatereferencesystem.cpp
|index 77c7081e455d..4cba529b89de 100644
|--- a/src/core/proj/qgscoordinatereferencesystem.cpp
|+++ b/src/core/proj/qgscoordinatereferencesystem.cpp
File to patch:
Kind regards
Piet
~/src/qgis/cpp/QGIS/src$ patch -Np1 -i /home/user/tmp/
4036e3d6ae71ffefc48a22295e338f59502949bb.diff
srs-fix.diff
Am 11.06.21 um 04:00 schrieb Saulteau Don:
> The patch resolved almost all of them! It's left a single CRS that
> couldn't be:
> Could not execute: INSERT INTO tbl_srs(srs_id,
> description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated)
> VALUES (63
> 321, 'Timbalai 1948 / RSO Sarawak LSD
> (m)','omerc','omerc','+proj=omerc +no_uoff +lat_0=4 +lonc=115
> +alpha=53.3158204722222 +gamma=53.1301023611111 +k=0.99984
> +x_0=2000000 +y_0=5000000 +ellps=evrstSS +towgs84=-679,669,-48,0,0,0,0
> +units=m +no_defs',520003321,'EPSG','29874',0,0) [UNIQUE constraint
> failed: tbl_srs.srs_
> id/UNIQUE constraint failed: tbl_srs.srs_id]
> 1 CRSs could not be updated.
> Tested on QGIS 3.18.3 and Arch Linux.
> To get the patch:
> 1.) Go to the issue that Andrea referenced at
> https://github.com/qgis/QGIS/pull/43671
> <https://github.com/qgis/QGIS/pull/43671> and click the "commits" tab
> 2.) copy the patch link with the clipboard button and paste that into
> your browser
> 3.) add .diff to it like so,
> https://github.com/qgis/QGIS/commit/4036e3d6ae71ffefc48a22295e338f59502949bb.diff
> <https://github.com/qgis/QGIS/commit/4036e3d6ae71ffefc48a22295e338f59502949bb.diff>
> that's the patch file =) download it or put it in a notepad and save it.
> This particular patch is being applied to 'master' so it's important
> to Find & Replace the reference to the /proj/ folder.
> It's because the /proj folder doesn't exist in the 3.18.3 source
> package and the patch won't apply.
> Then, you can change directly into the qgis source folder after you
> extract it, apply the patch, then make, make install.
> cd <qgis src directory>
> patch -Np1 -i <path to patch>/srs-fix.diff
> is an example of applying the patch with the 'patch' utility
> saultdon
> On Thu, Jun 10, 2021 at 4:42 AM APM <apschwimmer at apmland.de
> <mailto:apschwimmer at apmland.de>> wrote:
>     Dear Andrea,
>     thank you for that!
>     To be honest, I have no idea how to deal with a patch!
>     Maybe you can give me a short advice?
>     Kind regards
>     Piet
>     Am 10.06.21 um 13:35 schrieb Andrea Giudiceandrea:
>     > APM wrote
>     >> All blocks of the message contains
>     >> "NOT NULL constraint failed:"
>     > Hi Piet,
>     > I've submitted a patch https://github.com/qgis/QGIS/pull/43671
>     <https://github.com/qgis/QGIS/pull/43671> which
>     > hopefully fixes the issue.
>     > If you want, you could try if it works for you. In case, let me
>     know.
>     > Regards.
>     > Andrea
>     > Sent from:
>     http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>     <http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html>
>     > _______________________________________________
>     > Qgis-user mailing list
>     > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>     > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>     > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210611/64a3f8a1/attachment.html>
