[Qgis-user] Compiling messages Qgis 3.18.3
Andrea Giudiceandrea andreaerdna at libero.it
Fri Jun 11 03:09:29 PDT 2021
APM wrote
> So I copy and paste the file directly and stored it as 'srs-fix.diff':
if you've download the patch file from
https://github.com/qgis/QGIS/commit/4036e3d6ae71ffefc48a22295e338f59502949bb.diff
then you need to substitute in it, using a text editor, any reference to the
file to patch from
src/core/proj/qgscoordinatereferencesystem.cpp
to
src/core/qgscoordinatereferencesystem.cpp
before applying the patch.
Anyway, I think it could be simpler to use a text editor to directly change
your src/core/qgscoordinatereferencesystem.cpp in the source directory, just
substituting
at line 2402
if ( !ellipseMatch.hasMatch() )
with
if ( ellipseMatch.hasMatch() )
and at line 2413
ellipsoid.clear();
with
ellipsoid = "":
and then save and build again and install.
Regards.
Andrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
