[Qgis-user] Compiling messages Qgis 3.18.3
APM
apschwimmer at apmland.de
Fri Jun 11 04:55:56 PDT 2021
Dear List,
sorry, I give bad data.
My compiled Qgis version is not 3.18.3, it's
QGIS-Version
3.19.0-Master
QGIS-Codeversion
2066fd6fb9 <https://github.com/qgis/QGIS/commit/2066fd6fb9>
Kind regards
Piet
Am 11.06.21 um 09:24 schrieb APM:
> Hello Saulteau,
> I'm unsure, if I understand your information right.
> 1. Go to the issue that Andrea referenced at.... > ok
> 2. copy the patch link with the clipboard button.....
> I think this is the button on the right side beneath "Verified". If I
> press it in Firefox
> I have "4036e3d6ae71ffefc48a22295e338f59502949bb" in the browsers
> clipboard.
> So I copy and paste the file directly and stored it as 'srs-fix.diff':
> If I use the command
> patch -Np1 -i /home/user/tmp/srs-fix.diff
> I get the message:
> user at debian:~/src/qgis/cpp/QGIS/src$ patch -Np1 -i
> /home/user/tmp/srs-fix.diff can't find file to patch at input line 5
> Perhaps you used the wrong -p or --strip option? The text leading up
> to this was: -------------------------- |diff --git
> a/src/core/proj/qgscoordinatereferencesystem.cpp
> b/src/core/proj/qgscoordinatereferencesystem.cpp |index
> 77c7081e455d..4cba529b89de 100644 |---
> a/src/core/proj/qgscoordinatereferencesystem.cpp |+++
> -------------------------- File to patch:
> Kind regards
> Piet
> ~/src/qgis/cpp/QGIS/src$ patch -Np1 -i /home/user/tmp/
> 4036e3d6ae71ffefc48a22295e338f59502949bb.diff srs-fix.diff
> Am 11.06.21 um 04:00 schrieb Saulteau Don:
>> The patch resolved almost all of them! It's left a single CRS that
>> couldn't be:
>> Could not execute: INSERT INTO tbl_srs(srs_id,
>> description,projection_acronym,ellipsoid_acronym,parameters,srid,auth_name,auth_id,is_geo,deprecated)
>> VALUES (63
>> 321, 'Timbalai 1948 / RSO Sarawak LSD
>> (m)','omerc','omerc','+proj=omerc +no_uoff +lat_0=4 +lonc=115
>> +alpha=53.3158204722222 +gamma=53.1301023611111 +k=0.99984
>> +x_0=2000000 +y_0=5000000 +ellps=evrstSS
>> +towgs84=-679,669,-48,0,0,0,0 +units=m
>> +no_defs',520003321,'EPSG','29874',0,0) [UNIQUE constraint failed:
>> tbl_srs.srs_
>> id/UNIQUE constraint failed: tbl_srs.srs_id]
>> 1 CRSs could not be updated.
>> Tested on QGIS 3.18.3 and Arch Linux.
>> To get the patch:
>> 1.) Go to the issue that Andrea referenced at
>> https://github.com/qgis/QGIS/pull/43671
>> <https://github.com/qgis/QGIS/pull/43671> and click the "commits" tab
>> 2.) copy the patch link with the clipboard button and paste that into
>> your browser
>> 3.) add .diff to it like so,
>> https://github.com/qgis/QGIS/commit/4036e3d6ae71ffefc48a22295e338f59502949bb.diff
>> <https://github.com/qgis/QGIS/commit/4036e3d6ae71ffefc48a22295e338f59502949bb.diff>
>> that's the patch file =) download it or put it in a notepad and save it.
>> This particular patch is being applied to 'master' so it's important
>> to Find & Replace the reference to the /proj/ folder.
>> It's because the /proj folder doesn't exist in the 3.18.3 source
>> package and the patch won't apply.
>> Then, you can change directly into the qgis source folder after you
>> extract it, apply the patch, then make, make install.
>> cd <qgis src directory>
>> patch -Np1 -i <path to patch>/srs-fix.diff
>> is an example of applying the patch with the 'patch' utility
>> saultdon
>> On Thu, Jun 10, 2021 at 4:42 AM APM <apschwimmer at apmland.de
>> <mailto:apschwimmer at apmland.de>> wrote:
>> Dear Andrea,
>> thank you for that!
>> To be honest, I have no idea how to deal with a patch!
>> Maybe you can give me a short advice?
>> Kind regards
>> Piet
>> Am 10.06.21 um 13:35 schrieb Andrea Giudiceandrea:
>> > APM wrote
>> >> All blocks of the message contains
>> >> "NOT NULL constraint failed:"
>> > Hi Piet,
>> > I've submitted a patch https://github.com/qgis/QGIS/pull/43671
>> <https://github.com/qgis/QGIS/pull/43671> which
>> > hopefully fixes the issue.
>> > If you want, you could try if it works for you. In case, let me
>> know.
>> > Regards.
>> > Andrea
>> > Sent from:
>> http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
>> <http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html>
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210611/1f25b86f/attachment.html>
