[Qgis-user] Unable to use Raster Calc in Modeller
Ujaval Gandhi
ujaval at spatialthoughts.com
Fri Jun 11 10:51:05 PDT 2021
QGIS Raster Calculator syntax is hard to use, especially from the modeler
and I frequently end up with wrong results. My suggestion is to use the
GDAL Raster Calculator, which has much more friendly syntax and is easy to
configure from the modeler.
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/> [image:
Twitter icon] <https://twitter.com/spatialthoughts>
On Fri, Jun 11, 2021 at 10:45 PM Drew French <fullboarfarm at gmail.com> wrote:
> The native raster calculator does not seem to work in the Graphic Modeller
> when you use an algorithm result instead of an input. This is very
> frustrating as I wanted to build a model that relies on the calculator for
> the final output. I don't have an example but it is as simple as taking an
> original DEM, running it through an algorithm to extract a category of
> values, and then subtracting those values from the original. The formula is
> good - I tested it out in the normal processing toolbox, it works great!
> But I want to take that into a model so I can batch process. Thanks for any
> thoughts
> Drew French
> (715) 986-8088
> www.ecologicaldesign.land
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210611/7708cfc6/attachment.html>
