[Qgis-user] 'Thinning' features
    Ujaval Gandhi
    ujaval at spatialthoughts.com
    Fri Jun 18 06:33:40 PDT 2021
For Points, there's a simple solution using SAGA Point Thinning algorithm
<https://gis.stackexchange.com/questions/233032/reduce-number-of-points-in-polygon>.
For Lines I could not find anything built-in but after some tests and the
following solution seems to work well.
   - Use Processing Toolbox > Snap geometries to Layer. Select the same
   layer for both input and reference. Specify your tolerance
   - The nearby line features will be snapped. Now use the Processing
   Toolbox > Delete duplicate geometries to remove one of the overlapping lines
Let me know how it goes with your dataset.
[image: Logo] <https://spatialthoughts.com/>
Ujaval Gandhi
Spatial Thoughts
mobile: +91-8095684687
email: ujaval at spatialthoughts.com
[image: LinkedIn icon] <https://www.linkedin.com/in/spatialthoughts/>  [image:
Twitter icon] <https://twitter.com/spatialthoughts>
On Fri, Jun 18, 2021 at 4:54 PM ryanpeel <ryanpeel at gmail.com> wrote:
> I have these features that are 'near' each other by just a couple feet.  I
> want to remove one of them.  Basically, remove one (doesn't matter which)
> if
> it's in parallel proximity by x number of feet.  Is there a way to do this?
> <http://osgeo-org.1560.x6.nabble.com/file/t387303/8eSl3nIP6b.png>
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210618/6e1e490d/attachment.html>
