[Qgis-user] (re)colloring overlapping parts of multipolygons
    Alexandre Neto
    senhor.neto at gmail.com
    Sat Jun 19 10:53:06 PDT 2021
Hi Richard,
Are you looking for something on the fly? Or you can run some analysis?
Alex
A sábado, 19/06/2021, 15:54, Richard Duivenvoorde <rdmailings at duif.net>
escreveu:
> Hi List,
> I'm experimenting to create 'flower'-shaped polygons for a point layer,
> denoting the signal coverage of several directional radio transmitters on a
> pole (fyi: to find/locate bats with small transmitters).
> After some fiddling I came to the attached result for a point with 3 (but
> dynamic from attribute) transmitters using the following expression:
>  collect_geometries(
>  array_foreach( string_to_array("azimuths"),
>  make_circle( make_point(
>                 $x + "bereik_m"/2 * cos(radians(@element)),
>                 $y + "bereik_m"/2* sin(radians(@element))), "bereik_m" )
> The result being a multipolygon with overlapping parts.
> In this work the overlapping area'a are (apparently) the most interesting,
> as there the 'location' accuracy is highest.
> So my question: is there a way to give the overlapping area's really
> different colors.
> I've been playing with the layer rendering options, but ideally the area's
> in which there is no, 2 parts, 3 parts, and 4 parts overlapping should be
> differently colored..
> I could try to create more advanced expressions (or probably I would go
> for some python) for that, but I was hoping maybe there is another
> trick/idea to use current multi-polygons, without adding 'parts'
> Any help/tip is appreciated.
> Regards & TIA,
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210619/b3c7850b/attachment.html>
