[Qgis-user] Sum of field value within same cluster
Alexandre Neto senhor.neto at gmail.com
Tue Jun 22 03:12:15 PDT 2021
Hi Dario,
You don't need such complicated expression. There's a cluster variable that
returns the value for you. It's @cluster_value.
This is well documented here:
https://docs.qgis.org/3.16/en/docs/user_manual/working_with_vector/vector_properties.html#point-cluster-renderer
Hope it helped.
Alexandre Neto
QGIS Support
www.qcooperative.net
A terça, 22/06/2021, 09:55, Dario C <dario955i at gmail.com> escreveu:
> Hi,
> I think I'm on the right way using this expression:
> aggregate('LayerID','sum',"FIELD",filter:=intersects(buffer($geometry,60),geometry(@parent)))
> [image: image.png]
> In point cluster I set 5 mm as distance (size of symbol is 4mm), so I
> thought that the buffer of my expression needed to be 5. Actually 5 does
> not work, so I changed to 5 multiply by the scale of the drawing
> (1/12.000), so I set 60.
> The point is that it works not so precise. In the screenshot you can see
> that, when you have two cluster close each other, the total sum is correct,
> but some parts are shifted to another cluster.
> Thanks for your help
> Il giorno dom 20 giu 2021 alle ore 15:15 Dario <dario955i at gmail.com> ha
> scritto:
>> Hi,
>> I’m working on a big scale, so I need to see my points using point
>> cluster.
>> I’d like to see as label the sum of a specific field of the point of the
>> same cluster.
>> I started using aggregate expression and buffer intersection as filter,
>> but nothing good...
>> Thank you in advance.
>> Cheers mm
>> _
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210622/6b3c36a9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210622/6b3c36a9/attachment-0001.png>
