[Qgis-user] Reduce the file size of the shape file
Nicolas Cadieux njacadieux.gitlab at gmail.com
Tue Jun 29 21:26:14 PDT 2021
If you have made a shortest path analysis like a one to all or an all to all, then multiple paths will be created.  Select and object then look at the attribute table. Sort them to the top. There is a sorting icon for this.  You will see that you probably have multiple overlapping path selected. Send a screen shot or the file and I can take a look at it tomorrow morning. I am in Montreal time.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 29 juin 2021 à 20:26, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
> Nicolas,
> Thanks for your reply. Changing the field format and saving to a different file format did not work for me. Just now, I noticed that, Whenever I select one line feature for the "ShortestPath" shapefile, I see the following message at the bottom left corner of the window. For example: "2148 feature(s) selected on layer shortest path. i.e. More than one features appear at the bottom left corner for each line that I select. I am trying to figure out how this will appear as 1 feature instead of 2148 features.The tools such as simplify and dissolve did not work for me.
> Regards.
>> On Tue, Jun 29, 2021 at 4:43 PM Nicolas Cadieux <njacadieux.gitlab at gmail.com> wrote:
>> Hi,
>> To my knowledge no.  You could simplify the geometries but that would probably come with a resolution penalty (missing nodes).  You could perhaps change the field data type.  For example, an int data type will probably use less space than a float with a 16 decimal value.  A text field can be reduced to the minimum size needed.  You can also try to save the file under an other name.  Depending on where the file was created and used, saving the file could “permanently delete” some previous deleted components.  Can you use another file format?
>> Nicolas Cadieux
>>>> Le 29 juin 2021 à 15:53, krishna Ayyala <ayyalakrishna at gmail.com> a écrit :
>>> Hello,
>>> I have a "Streets" shape file of a state with about 12000 lines. For the same geographic area I have "Blocks_Centroids" shape file of about 6000 points. I ran the tool as shown below. It resulted in a shapefile "ShortestPath" with 6000 lines. The size of the "Streets" shape file with 12000 lines is 5000 KB. Whereas the size of the output shape file  "ShortestPath" with only 6000 lines is 270,000 KB. Is there a way to reduce the file size? The reason is I need to upload this in a different platform which cannot accept shapefiles larger than 10,000 KB.
>>> <image.png>
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210630/3f118384/attachment.html>
